Becareful What You Do....
   / Becareful What You Do.... #21
Maybe a little of that - CausticUrbanCoast. But my 80 acres is all Ponderosa pine. Nothing like the growth( jungle ) I see in the pics others post. Loooong ago, when I cut my pines for firewood, I had one gigantic pine - kick back. Barber chair - ?? I was at quite a distance when it fell. Had I been behind the cut - I'd have been sliced in half. I was falling pines - 32" to 40" on the butt.
I soon learned that the really big pines were just too much of a PITA to be falling for firewood. Required too much planning in the falling and the rounds, cut to 16" long, were a real ***** to get up on the splitter and split. I had the property selectively logged and I went with the pines - 20" or less for firewood.
I don't burn wood for heat, so this is just an educational question.
I always heard that around where I live, people do not burn pine, due to creosote, sap, or whatever, being deposited in the chimney and possibly resulting in a chimney fire.
Is this just a wife's tale?
Seriously, just curious...
   / Becareful What You Do.... #22
It has a higher sap content depending when you cut it and which pine, so it can burn a lot faster and hotter. Which is not a bad thing, but you should mix it with other wood to increase burn time and finish with a hardwood of some type if you can.
It also needs to be seasoned, burning green/wet is a last resort as you will get a lot of creosote buildup since it will not burn hot enough to keep your chimney clean.
Makes good kindling and initial startup logs. If you have an open fireplace it also tends to spit sparks and embers more than other wood.
   / Becareful What You Do.... #23
The ONLY wood I burned for 18 years - Ponderosa pine. That's all I have here on the property. I seasoned( stacked up to dry out) it for a full year before burning. It burned hot and provided good heat.
I never had any problems with creosote. Brush down the chimney every fall before starting the stove. Never got more than a quarter cup of creosote.
Would I have rather had other types. I cut down my old apple orchard and burned it. Not that much different than pine. Except - a whole lot more ash.
Went down the road a couple miles and cut down two black locust trees that were on an old homestead. Seasoned for a full year prior to burning. That WAS some very fine firewood. Good heat and properly banked - the fire held all night. After seasoning for a year the locust was hard as a rock. If I had access to more - split while it's green - then rack up to season.
Splitting after a year of drying - that locust gave my hydraulic splitter a good workout.
After 18 years we quit burning firewood and went to pellets. Got tired of all the dirt, bugs and volcanic ash ( Mount Saint Helens - 1980 ) brought into the house with the wood.
   / Becareful What You Do.... #24
Pine has higher moisture and sap when green. It dries faster. Any dry wood will burn clean. Only disadvantage of pine is the lower BTU content.
   / Becareful What You Do.... #26
Exactly the same for me. Pine, aspen, and Fir. After the fire last year I have so many trees to take down I will never, ever run out of firewood.
   / Becareful What You Do.... #27
WOW, there's no good way out of that. Thanks for sharing, I need a good reminder every now and then to slow down and take a second look.
   / Becareful What You Do.... #28
It's been a long time since I heated with wood, but, doesn't pine also tend to pop a lot and throw sparks? In a closed wood stove I guess that's fine, but when you open it, or if you have a fireplace, seems a bit scary. A wood fire is only nice when the wood isn't part of your house.
   / Becareful What You Do.... #29
In my experience, not if it's dry.
   / Becareful What You Do.... #30
That's cool but I'm just wondering how you would get that down without crushing yourself or damaging the tractor further? Slowly chunks out of the top of the tree and let the weight of the tractor set it back down?
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2013 HYUNDAI Veloster Hatchback (A56859)
2013 HYUNDAI...
30in Hydraulic pallet Forks Skid Steer Attachment (A56857)
30in Hydraulic...
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
2016 DODGE RAM 3500 FLATBED (A58214)
2016 DODGE RAM...
