Bearcat Chipper with blower question
/ Bearcat Chipper with blower question #1
TXin180
East Texas
NH 3415
I have a Bearcat 70554 with 2 speed blower I got used. The belts on the blower were bad when I got it so I put new belts on both chipper and blower. The new blower belts I put on it were BK55 belts.
My question is, it wont stay in slow speed. there does not seem to be much movement available on the blower speed lever. When it is running, moving the speed control towards slow does slow it down but it wont stay, it creeps back over to fast. The lever only moves an inch or two towards slow or fast from the middle position. I hoped someone that has one could say how theirs operates? Also it crazy how much force the blower has, it make a depression in the ground wherever I use it : )
Thank you
/ Bearcat Chipper with blower question #2
I just have a single speed blower on mine. I didn't know there was a dual speed blower so I won;t be much help. How does it work ? 2 belt and pulley sets. One belt slips and the lever tightens the other depending which way you push it maybe ? Do you just need more friction on the lever pivot or a way to lock it in position? A picture would be interesting. This is mine - its old
gg
/ Bearcat Chipper with blower question #3
Or maybe it is a caming type lock and you just arn't pushing the lever hard enoungh to get it to cam over into the locked position. Belts to short ?? or needs adjustment somewhere ? Picture....
gg
gg
Hey I received a reply from Crary about my 20+ years old machine . . . I believe I have the belts 1" too short. I used a Gates 6958 cross ref instead of the factory spec Gates 6959.
I have some on the way, will see whats up after changing them. Hopefully it is just that easy.
Thank you Gordon
OK after receiving the correct belts for the blower (6959 GATES Kevlar Replacement V-Belt 5/8 x 59 ) I gave it a good 4 hour workout, worked perfectly. Thanks
/ Bearcat Chipper with blower question #6
:thumbsup: Sounds good
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
Pemberton Inc Komatsu Grapple Bucket (A64194)
Pemberton Inc...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
