BCS 853 Losing Power
   / BCS 853 Losing Power #1
TimtheTractorMan
BCS 853
I have a BCS 853 with a Honda engine. We've been getting a ridiculous amount of snow, and I was snow blowing with it and it gradually kept losing power - the snow was being thrown a shorter and shorter distance, until eventually it won't even make it out of the chute and it clogs up. At first I thought it was the throttle icing up, but I adjusted that.
I left it for a while, made sure it went through a thaw, and tried it again, and it's still doing the exact same thing. It starts up great, runs fine, I can drive it around, everything is spinning and turning, not making any weird sounds - it just doesn't have enough power to throw snow (even light fluffy snow).
Any thoughts what I should investigate?
   / BCS 853 Losing Power #2
Any chance since your blowing snow the gas cap vent is icing shut and or the air filter is icing up?
No, I waited and made sure everything was clear of snow/ice before trying again, including taking the air filter off and having a look.
   / BCS 853 Losing Power #4
Crack the fuel filler cap and see if it improves while under load, very common issue
Another thing I have seen multiple times on people’s tractors is a leaf or debris that will cover the fuel pickup point in the tank and then float away when it’s off just to be repeated
Last would be to clean the carb jets encase they became plugged with a small piece of dirt or debris.
   / BCS 853 Losing Power #5
You're governor is freezing up. I had the exact same problem on my 739. It's below freezing but there's a lot of wet snow flying all over everything. The water lays on top of the engine between the tank and the air cleaner/muffler and freezes. That's right where the governor is. It freezes the governor solid. Bad design by BCS/Honda. I ended up making an engine cover for mine to keep the engine dry. Completely solved the problem. Or wait until it gets warmer to clear your snow.
   / BCS 853 Losing Power #6
I also had this problem and built a prototype engine cover out of cardboard and tinfoil. It solved my problem.
Most dedicated walk-behind snow blowers have full engine cowling so it makes sense that non-dedicated snowblower also needs one.
   / BCS 853 Losing Power #7
Here's a thread I started on the subject. There's a picture of the engine cover I made.
  • Good Post
Reactions: D&D
   / BCS 853 Losing Power #8
This sounds like it could be diagnosed with a hair dryer blowing at the area for 10 to 15 minutes? A hair dryer won't fix the problem but it it runs properly after melting and drying everything out then it would be a pretty clear indicator this is the problem.
Potato Scrub Brush Washer (A47369)
Potato Scrub Brush...
2007 Dodge Charger Sedan (A46684)
2007 Dodge Charger...
Skid Steer Hydraulic Hammer SSHH680 (A43476)
Skid Steer...
2018 Schulte FX107 84in Rotary Cutter Attachment (A46683)
2018 Schulte FX107...
DigMaster DM100 Mini Excavator (A43476)
DigMaster DM100...
(2) 445/50R22.5 Road Tractor Tires on Rims (A43476)
(2) 445/50R22.5...
