Bcs 605
/ Bcs 605 #1
jerzeemaple
I picked up a sweet 605 with BCS combo mower and an 8hp kohler magnum, purrs like a kitten. Thinking about adding more hp for other attachments, is it as simple as swapping my motor with a new one,like a 13hp honda, and nothing else like adapters would be required?
/ Bcs 605 #2
Candidly, my experience with the Honda engines is awful.
The fumes created by the GX340 I had on my TW5-FC commercial firewood splitter were so bad I bought a
catalytic converter from Foley engine service to clean the exhaust to convert it to CO2 and water vapor and I never had an issue after that. I only use premium gasoline and Seafoam gas treatment in my all my fuel.
I would purchase a Hatz diesel with an oil bath air cleaner and a Hatz recommended muffler before I invested in a Honda replacement.
/ Bcs 605 #3
I put a Honda on my BCS 850 (just a newer 605 I think). I sent the clutch to Earthtools, they mounted the adapter and clutch, all I had to do was mount the unit, hook up the cables, put gas&oil in, turn the key and go.Love the motor, love the tractor. We run that same engine on a lot of heavily used and abused equipment like Christmas tree balers, easy to service, easy to crank. Joel can tell you exactly what you need, but to be honest, my 725 had the 8hp Kohler and it was a hoss, I might try those power hungry implements first before I bought a new motor.
/ Bcs 605
What motor did you have on your 850 before going to the Honda?
/ Bcs 605 #5
Briggs, V14. Had some fuel issues I didn't have time or energy to deal with.
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A63569)
2012 SOUTHERN VAC...
2016 PETERBILT 579 (A63569)
2016 PETERBILT 579...
ALUMINUM HEAD ACHE RACK (A63569)
ALUMINUM HEAD ACHE...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
SET OF (9) PUMP BOXES (A63569)
SET OF (9) PUMP...
