Battery wont charge.
/ Battery wont charge. #1
wedge40
/ Battery wont charge. #2
Batteries left in a state of discharge can corrode the plates and cause an internal short.
Also, is the battery AGM? You may not have enough charger for that battery. The tender is designed to maintain a full charge on a battery not charge a dead battery.
I would recommend getting the battery tested for a short.
/ Battery wont charge. #4
You either need a larger charger to get it started or like Tom said connect it to a good battery to get it started after a few mins. of it going you can disconnect the good battery.
/ Battery wont charge. #5
Bigger output charger is needed.
/ Battery wont charge. #7
The Optima Battery is not like a normal lead acid battery
read the tech tip above it needs a charger that recognizes what type of battery it is to charge or like above hook up a partially charged battery in parallel to fool the charger but charge on slow not high!
/ Battery wont charge. #8
"it is dead, Jim"
I see that Dead Horse watched all of the Star Trek marathons they showed due to the passing of Leonard Nimoy. As a proud nerd (just look at my screen name), I'd like to add:
Darn it, Jim! I'm a doctor, not a battery mechanic!
And now, let's hope that will help Wedg40 forget his battery trouble for a moment.
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2016 Ford F-150...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2022 EZ-GO ELITE...
REDDICK OFFSET DITCHER, 3PT (A64278)
REDDICK OFFSET...
2022 EZ-GO ELITE...
