Battery question
/ Battery question #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Battery in my wife's motorcycle is 3-4 years old. I find that I generally don't get much more than that out of them.
It's been kept on a quality tender all winter and still didn't want to start. Long story short as I can make it - it was nearly dry. Filled with distilled water and put on Pro Logix charger. Charger brought it up to 97% and then went into the Energizing Phase mode where it supposedly conditions the battery. After a day or so of this the battery gets to 100% and charge is complete.
I took it off the charger and let the battery rest on the bench overnight. This morning I put the charger back on and it shows 84% charged. This probably is not an acceptable drop for an unloaded battery overnight. But I'd like someone who knows more about this than me to verify that.
I already ordered a new battery yesterday so it's kind of moot, but I like to learn about these things and file away for future reference.
/ Battery question #2
Long time motorcyclist and automotive tech here. When I have had a battery get that low on water I've had no luck trying to save it.
/ Battery question
I rolled the dice on a couple of $35 AGM batteries. Awaiting shipment. We'll see out it goes. I'm not out a ton of money if it doesn't work out.
I have a feeling that you're right that the current battery is not long for the world.
/ Battery question #4
Back when I rode I always had good luck with NAPA legend batteries.
/ Battery question #5
I got 9 years out of my original motorcycle battery (Yuasa)
Set for months through the winter. Never had a battery tender on it.
/ Battery question #6
That is n excellent price for AGM batteries if quality is good, keep us posted.
/ Battery question
I now have a pair of Yuasa tenders. So far so good with them.
Here's where I ordered them. Deka ETX2L replacement Motorcycle Battery (12V 18Ah)
I'll report back on how it works out. May take a few months of use.
I'm not a lover of battery tenders left on small batteries for long periods of time for this very reason. I think a lot of them give something .75A charging current. If you have a 7 AH battery, in 10 hours the battery is at a point of overcharging. If it's a smart charger that goes into a maintenance mode, what is the charging current at that point?
I'll have to dig out the literature on the charger if I can find it. It's Harley Davidson branded. No idea at the moment of who made it for them.
/ Battery question #8
I had the same problem with lawn mower batteries. What I do now is take them inside for the winter. I put them up on a shelf in the basement. By doing this I occasionally see them sitting there and will connect them up to a charger for a day (maybe once or twice a winter). I haven't had to replace a battery now in the last 10 years. Before doing this I was converting any motorcycle/ ATV to taking a lawn mower battery because they were half the price of a motorcycle battery.
/ Battery question #9
Mine go to zero... Then come back on as needed.
SR
/ Battery question #10
I've had unbelievable battery life since I started using Deltran chargers 15 years ago. I have them connected to something all the time and never had one get low on water,much less go dry. The key isn't charging the battery before using it,it should be at 100% as much of time as possible. Quick charging is poison to batteries. If at all possible,you should slow charge battery rather than boosting then allowing vehicle to charge it up.
/ Battery question
I have pigtails attached to the batteries in both of our bikes. They're in an unheated attached garage year round. Generally I just go out once a week or so and switch the tender from one bike to the other.
Over the last several years I've found that I only seem to get 3, maybe 4 years out of a bike battery. This sucks at $100+ at the local NAPA. I'm hoping these 2 $35 AGM batteries that were delivered yesterday will have a longer life. But if they're the same or slightly less long lived I'm still money ahead.
I always go with a 2 amp and let it take as long as it needs if the batteries get down for some reason.
/ Battery question
First of the $35 AGM batteries was installed in my wife's bike yesterday. I checked it with a Pro Logix charger before installation to make sure it was up after being shipped here. It was at 100%.
Flipped the motor over quick and started right up. Now only time will tell about the durability and longevity. I figured it was worth a shot for the price.
While I was messing with batteries/chargers I decided to check my own bike. Sealed battery with a date sticker on it of 1/12. I don't ever remember getting that much out of a battery. I did start the bike last week and took it for a little 1 1/2 mile cruise to make sure everything was OK. Yesterday the Pro Logix showed it still at 95%.
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
2716SFL (A61567)
2716SFL (A61567)
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
