Battery powered chainsaw
/ Battery powered chainsaw #1,021
Agree with the battery powered leaf blower, those are amazing. I have an 18v one in my shop and I regularly use it with just a hint of pressure on the trigger to "sweep"; I'd only used the gas one for doing large areas but now I use this for all kinds of things - and without the long nozzle (comes off easily) it fits nicely behind my tractor seat for hogging radiator blow-off.
I'm loving the Echo DCS-2500T. I haven't cut down any trees with it, but lots of small work. Being able to set it down anywhere (not hot), then easily grab it and make a few cuts, set it down, etc, game changer. Chopping up lots of wood at once, I'm tireless with it, it's so lightweight. My chores are over before the battery is run down too.
I'd love to get a 60cc equivalent battery saw, but I won't put up with an extra heavy saw - sticking with the gasser for bigger stuff for now.
/ Battery powered chainsaw #1,022
I used my 40V Ryobi just yesterday. It amazes me how well it works very times I use it. I have a Stihl for big stuff, but it hasn’t been fired up in at least a year.
/ Battery powered chainsaw #1,023
I would like to get a decent battery saw but none seem to have good reviews. They either have "Pico" chains, leak oil or come with "no tool" tensioners that give problems.
I would prefer a 3/8" pitch chain, and a 12-16" bar. My primary task is cutting out crotches and bad twists on firewood logs as my processor does not have a large capacity.
If I drop $500 on a decent saw I want it to last 15 years even if the battery is only good for 5 years.
Does such a critter exist?
/ Battery powered chainsaw #1,024
If you already have Stihl AP series batteries and charger there are several saws not pico.
Also Stihl actually has sales and promos now...
5 years and no battery or oil problems...
I did spend $1800 for saw, blower,, pole saw, trimmer etc.
/ Battery powered chainsaw #1,025
I love my little M18 blower for the deck areas.
I have 3 blowers, 2 are gas for driveways etc.
But I find myself using the battery one most of the time.
Have been using my Ryobi Poll saw the las few days trimming the tree limbs back from the fence lines. The battery that comes with it is a bit small but I just change it out with my Ryobi chainsaw battery and continue on. By the time I kill off two batteries. I'm ready to stop and clean up all the mess.
This mini ex I purchased with thumb has been a great help in cleaning up the mess .
I make large piles with the mini ex, then bring in the tractor with grapple and move all the tree limbs back to the burn pile.
I ain't getting any younger, so It's great to have the tools to make these job easier.
/ Battery powered chainsaw #1,027
Pushed over five dead standing PPines, 12-16". Been dicing them into firewood lengths and splitting immediately. Maybe the wicked moisture will evap and I can burn them by spring if we have an an extraordinarily cold winter. I get through the trunks with the Husky Rancher but I don't like to limb with a skip tooth 20". So I grab the electric Ryobi with a mostly fresh chain and battery. On the 3rd limb it threw the chain.
You don't go from one to the other without resetting your production gauge. They are good but they are toys.
/ Battery powered chainsaw #1,028
Well, I broke down and got a cheap battery saw. The 12” Dewalt 20v. I have four batteries already and got a great deal on the tool. $130 after my ACE discount and a rebate from my electric provider.
Should be nice and light to trim off small branches/crotches that need to be removed to get larger logs through the processor.
Can’t see spending over $400 for the limited uses I have unless I cannot get the 48cc Shindiawa repaired.
/ Battery powered chainsaw #1,029
You are going to find you use it more and more. I hope you have the large batteries. I find mine is weak with the small batteries. I have to remember to run the gas out of my Stihl because I use it so seldom now.
/ Battery powered chainsaw #1,030
I have two of the 5 amp-hr batteries. Should never need the smaller ones for my needs.
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
Advanced EV Cart NR (A59231)
Advanced EV Cart...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2025 AGT Industrial MX-CRT23 (A60463)
2025 AGT...
