Battery maintenance
/ Battery maintenance #1
jem041279
Abbeville, La
2011 Kubota L3940 4x4 w/ FEL & John Deere 750
LSU, LSU, LSU..... Sry could not resist as I just finished watching the game, now on to business, I am thinking of installing a 2 amp charger on my L 3940. I plan on bolting it in place somehow so I can just plug it in when I feel I need to. My question is due to my job working offshore, I may be gone for a week or two at a time and was wondering would it be ok to leave it charging for that long?
/ Battery maintenance #2
Get you a trickle charger. They are more like 1/2 to 1 amp and some will kick on and off. 2 amps is kind of big running 24/7.
/ Battery maintenance #4
I've got the tender jr and regular tender and the save a battery chargers...
They all work well and I highly recommend any of them.
The marine versions cost a little more and are better protected from the elements and impact as it was told to me.
/ Battery maintenance #5
I kept a battery tender on my Harley for years.
/ Battery maintenance #7
Depends. A float charger is good indefinitely, but a trickle charger will overcharge a battery eventually. Buy a Deltran Battery Tender - they're good for just about any situation. If you only need a charger for storage maintenance, then just get a float charger from Harbor Freight for $6. I have a half-dozen batteries (including my tractor) plugged in pretty much full time using the cheapo HF float chargers.
JayC
Thanks for reply fellows I will look for a float charger
/ Battery maintenance #9
Do not forget your 20 percent off coupon at HF. I have not looked at the tools that work list and wonder if this charger is on it.
/ Battery maintenance #10
if tractor is going to set a long time. i would advise pulling it from tractor, and setting it a piece of wood up on a shelf. as long as not on floor. and putting automatic charger that turns on/off on its own.
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
Case SV280B (A60462)
Volvo EC220EL (A60462)
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
MAMMOTH AIR CONDITION PACKAGE UNIT (A64281)
MAMMOTH AIR...
