Battery light indicator.
/ Battery light indicator. #1
rfkulka
Orange CT
John Deere 650
Started my newly acquired used B7800 today. I noticed the battery light indicator stays illuminated while the tractor is running. Is this normal or an omen of a possible problem. I"m new to the machine and being such a novice is embarrasssing. I'm thinking it may be an alternator issue or maybe no issue at all. Can anyone put my mind at ease? Should I check the charging with an ammeter. The owners manual does not address the issue. Thanks for any any info you care to share. I will be appreciated.
/ Battery light indicator. #2
the light should go out after a bit, check with a voltmeter. volts will go to 14 or so then settle down to 12.5.
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
Tool Bar (A64127)
Tool Bar (A64127)
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Harlo HP6500 (A60462)
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
7888SFL (A61567)
7888SFL (A61567)
