Basic firewood rack.
/ Basic firewood rack. #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
I wanted a rack that I could locate under a deck. It is south-facing so protected from rain and snow but gets some prevailing breeze and sun all day.
Looked around and this style seemed to work. I was thinking you would need so outside braces but people jut box in the end pieces.
(2) 2x4x10' pressure treated
(3) 2x4x8' pressure treated.
box of 3.5" exterior screws.
/ Basic firewood rack. #2
Looks a lot like the one I have under my deck except I used a single 2x4 on each end and added a board across the top to tie the ends together. I use it for short term storage since I have a walkout and the stove is in the basement right next to this location.
/ Basic firewood rack. #3
Looks very similar to mine. I used 14ga 2x2 tubing.
CT
/ Basic firewood rack. #4
Had a similar rack and it worked like a charm... kept it under the deck until the Fire Marshall said it had to be 20' away from the structure... I left it natural and the elements took a toll after a couple of years.
/ Basic firewood rack. #5
About like I made, but I made the sides wider and put diagonals across the back since I don't trust PT lumber to stay straight when it's sticking in the air. So of course the two vertical 2x4 pieces in back stayed straight, and the front ones twisted!!
I just moved mine under the front porch for the summer. Come fall, it will go back up on the porch near the front door.
/ Basic firewood rack. #6
I was looking at making some 4W' x 4L' x 3'H firewood "Baskets" using hog panels welded to 2" square tube frames. I figure I could use the FEL and pallet forks to move them around.
That was my plan but I think I'll make one narrower and taller for the porch, and tie the top together.
/ Basic firewood rack. #8
How would you bend the hog panel to make the corners? Or are you planning on cutting it and wiring it back together. I tried bending a tight 90 in it once before I had my loader and it turned out to be quite a chore.
I looked at some of the steel tube kits but they were too cheap to be rugged and expensive compared to wood. If I could have found sometight from, say, 1x2" rectangular tube I might have bought it. Not a high-tech application....
/ Basic firewood rack. #10
I was looking at cutting them. Instead of wiring I thought I might try using chain quicklinks to connect the corners. This way maybe I could make the baskets collapsible. I don't have it all thought out yet, I have a ton of projects ahead of it, but was giving it some thought. Essentially, I'd have a 48" x 48" square-tube "pallet" with hog panel sides that could fold flat for storage or be stood up with the quicklinks holding the corners together.
/ Basic firewood rack. #11
I was using skids before and I changed to these. Easier to load and move, they can be stacked but the length I had cut this wood I can't use the kickers for the rack. Well be stacking after I split what I have cut now. I have forgot what the log has to be for stacking, I think it's 20". The racks were FREE.
/ Basic firewood rack. #12
Gman, I make and use those same racks, except I put a 2x4 on top to keep the two uppers together.
/ Basic firewood rack. #13
I found these for $25 and thought what the heck and bought 4 I will pick up 2 more next time I am in that neck of the woods.! They hold about a face cord (16x48x96) and move around easy with the forks. I haven't used them during a winter yet, I'll have to wait and see how they are to use next winter.
/ Basic firewood rack. #14
I've been looking for a source for those locally... both the pallet and the IBC totes for water storage.
Any ideas on where to find for a reasonable price like $25?
/ Basic firewood rack. #16
So far I have found only complete totes... average about $125
Will keep checking...
/ Basic firewood rack. #17
I found mine on CL also. With the plastic container they were $40, without $25. I did not need the liner so I left it with the seller. No hassle, no getting rid of the liner once I got them home.
/ Basic firewood rack. #18
You guys must be tall, I'm short and would have a hard time unloading.
/ Basic firewood rack. #19
I use these for my drying areas as well as under the deck for my winter storage. 6 landscape timbers, 5 cinder blocks, no nails or screws and can put them together in about 2 minutes. Plus when i empty a rack i can move it all out of the way and stack the blocks up. They keep the wood off the ground, stack out about 16'long and i go about 4'high.
/ Basic firewood rack. #20
I'm wondering if one side could be notched or otherwise have a section or part or the side removed for access?
2010 CHEVROLET PICKUP 3500 HD 4X4 CREW CAB (A59912)
2010 CHEVROLET...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
208735 (A60430)
208735 (A60430)
JOHN DEERE 94520R ARTICULATING TRACTOR (A64280)
JOHN DEERE 94520R...
2025 B and B Fabrication CT3500MRT Towable Reel Tensioner (A61572)
2025 B and B...
Unverferth Seed Runner 3755 (A64119)
Unverferth Seed...
