Basic firewood rack.
/ Basic firewood rack. #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
I wanted a rack that I could locate under a deck. It is south-facing so protected from rain and snow but gets some prevailing breeze and sun all day.
Looked around and this style seemed to work. I was thinking you would need so outside braces but people jut box in the end pieces.
(2) 2x4x10' pressure treated
(3) 2x4x8' pressure treated.
box of 3.5" exterior screws.
/ Basic firewood rack. #2
Looks a lot like the one I have under my deck except I used a single 2x4 on each end and added a board across the top to tie the ends together. I use it for short term storage since I have a walkout and the stove is in the basement right next to this location.
/ Basic firewood rack. #3
Looks very similar to mine. I used 14ga 2x2 tubing.
CT
/ Basic firewood rack. #4
Had a similar rack and it worked like a charm... kept it under the deck until the Fire Marshall said it had to be 20' away from the structure... I left it natural and the elements took a toll after a couple of years.
/ Basic firewood rack. #5
About like I made, but I made the sides wider and put diagonals across the back since I don't trust PT lumber to stay straight when it's sticking in the air. So of course the two vertical 2x4 pieces in back stayed straight, and the front ones twisted!!
I just moved mine under the front porch for the summer. Come fall, it will go back up on the porch near the front door.
/ Basic firewood rack. #6
I was looking at making some 4W' x 4L' x 3'H firewood "Baskets" using hog panels welded to 2" square tube frames. I figure I could use the FEL and pallet forks to move them around.
That was my plan but I think I'll make one narrower and taller for the porch, and tie the top together.
/ Basic firewood rack. #8
How would you bend the hog panel to make the corners? Or are you planning on cutting it and wiring it back together. I tried bending a tight 90 in it once before I had my loader and it turned out to be quite a chore.
I looked at some of the steel tube kits but they were too cheap to be rugged and expensive compared to wood. If I could have found sometight from, say, 1x2" rectangular tube I might have bought it. Not a high-tech application....
/ Basic firewood rack. #10
I was looking at cutting them. Instead of wiring I thought I might try using chain quicklinks to connect the corners. This way maybe I could make the baskets collapsible. I don't have it all thought out yet, I have a ton of projects ahead of it, but was giving it some thought. Essentially, I'd have a 48" x 48" square-tube "pallet" with hog panel sides that could fold flat for storage or be stood up with the quicklinks holding the corners together.
/ Basic firewood rack. #11
I was using skids before and I changed to these. Easier to load and move, they can be stacked but the length I had cut this wood I can't use the kickers for the rack. Well be stacking after I split what I have cut now. I have forgot what the log has to be for stacking, I think it's 20". The racks were FREE.
/ Basic firewood rack. #12
Gman, I make and use those same racks, except I put a 2x4 on top to keep the two uppers together.
/ Basic firewood rack. #13
I found these for $25 and thought what the heck and bought 4 I will pick up 2 more next time I am in that neck of the woods.! They hold about a face cord (16x48x96) and move around easy with the forks. I haven't used them during a winter yet, I'll have to wait and see how they are to use next winter.
/ Basic firewood rack. #14
I've been looking for a source for those locally... both the pallet and the IBC totes for water storage.
Any ideas on where to find for a reasonable price like $25?
/ Basic firewood rack. #16
So far I have found only complete totes... average about $125
Will keep checking...
/ Basic firewood rack. #17
I found mine on CL also. With the plastic container they were $40, without $25. I did not need the liner so I left it with the seller. No hassle, no getting rid of the liner once I got them home.
/ Basic firewood rack. #18
You guys must be tall, I'm short and would have a hard time unloading.
/ Basic firewood rack. #19
I use these for my drying areas as well as under the deck for my winter storage. 6 landscape timbers, 5 cinder blocks, no nails or screws and can put them together in about 2 minutes. Plus when i empty a rack i can move it all out of the way and stack the blocks up. They keep the wood off the ground, stack out about 16'long and i go about 4'high.
/ Basic firewood rack. #20
I'm wondering if one side could be notched or otherwise have a section or part or the side removed for access?
Chevy 2500 HD 4WD (A63689)
Chevy 2500 HD 4WD...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
KUBOTA BT1973 - 17 1/2" EXCAVATOR BUCKET (A64280)
KUBOTA BT1973 - 17...
US ELECTRICAL TOOL CO.-500B BALL BEARING GRINDER (A64280)
US ELECTRICAL TOOL...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
UNUSED WOLVERINE HYD ADJUSTABLE BALE SQUEEZE (A64281)
UNUSED WOLVERINE...
