basic electrical help - adding LED flood lights
/ basic electrical help - adding LED flood lights #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
im not much for electronics or wiring but maybe i can change this. i have an old rear floodlight that was added to my tractor that has burned out. it has a black and red wire and is wired so it can only be on when the key is on. could i just replace this with an LED flood light? once i figure out what i need i might want to add one or a maybe even a light bar for the front. please let me know what i might need. i am also going to do this for my new polaris ranger but i dont really understand what i need to do. thank you in advance!
/ basic electrical help - adding LED flood lights #2
If your bulb has burned out, you may be able to find an LED that fits the socket.
If you buy an LED that has its own enclosure, then remove the old light and install the new one.
There are to many small things to tell here so suggest you find some youtube videos to see how to wire lights.
Disconnect the battery before you start.
Basically, red is usually positive, black is negative and should be connected to the frame with a bolt or screw. You should be able to use the old wires for that and it will work just like the old one.
/ basic electrical help - adding LED flood lights #3
Your old floodlight was probably an incandescent lamp, meaning one with a filament inside. As such it won't matter if your polarity is reversed. However, LEDs matter for polarity. Other than that LEDs can be installed as replacements and will use much less current, less heat, and usually more light.
/ basic electrical help - adding LED flood lights #4
If the led light fixture you get is made specifically for a 12V (assuming your tractor is 12V) system, yes, it will just simply replace the fixture that is there.
thank you!
/ basic electrical help - adding LED flood lights #6
If you were wondering, since an LED draws much less current than an incandescent light for the same output, you are safe electrically dropping one in as a replacement, either at bulb level or the whole assembly. Within the warnings above, you're always good substituting things that draw less current. It's replacing an LED with an incandescent that could lead to trouble (though I don't know why anybody would want to).
/ basic electrical help - adding LED flood lights #7
great info - exactly what i need. thank you !!
/ basic electrical help - adding LED flood lights #9
/ basic electrical help - adding LED flood lights #10
check the wattage on the bulb
watts divided by volts = amps
so if its a 100 watt bulb divided by
12 volts = 8.33 amps
so you can use an led up to 8 amps
with no problem just make sure its
a 12 volt led
with; your volt tester turn the light on
put your black lead on ground and the
red lead in the center if you get voltage
the center is the hot or plus side
willy
/ basic electrical help - adding LED flood lights #11
Question: If the thing is wired to the lights, doesn't the current go through a relay from the ignition switch? if so, the current theoretically could be too much for the relay, if you put a huge light bar to replace on incandescent light, but even then not likely, no? The ignition switch doesn't carry the entire load of all the lights, does it? I have always assumed there was a relay. It would seem to take a lot of LEDs to add significant wattage to the system.
/ basic electrical help - adding LED flood lights #12
Most lights require a relay because the switch
would not last very long they are not made to
handle very many amps. With the relay installed
you can use cheap switches
willy
90in. Work Bench (A65640)
90in. Work Bench...
2019 HINO 268 26FT 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 26FT...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
Cattle Feeder (A65640)
2009 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2009 INTERNATIONAL...
