Barndominium/Shop or "real" House?
   / Barndominium/Shop or "real" House?
Are you going to install the insulation yourself? Cutting and fitting it into those cavities is not going to be fun.
Not sure. I've been deciding as I go along what tasks I do myself. I've done insulation before so can do it, but just like drywall I hate doing it so hopefully can find someone to get it done in the timeframe I need.
   / Barndominium/Shop or "real" House? #602
If it’s not too late I would dig a small footing on the perimeter to allow for a thicker edge with a couple bars of # 4 in it. It serves two purposes. First it keeps the material under the slab from migrating out leaving a void and the increased strength is needed on the edge since tires put 100% of their weight there until they get further out to gain a larger support area.
I have been doing it for over 50 years since I started. Learned the hard way. I have poured over 450 yards on my home project around here and did my last about 6 months ago when the price reached $200 per yard. Thanks to CA politicians and their environmentalists
   / Barndominium/Shop or "real" House? #603
You might also think about some decorative work outside. I stained my porch to go with my stone work and I have more to do.
   / Barndominium/Shop or "real" House? #606
The way I see it is if you’re knowledgeable and willing to work that’s the way to go. I have built 5 new houses for ourselves two without subs and three with Sheetrock subs, mainly because the ceiling was 18’ 6”. Sometimes it takes years but I don’t like their work quality (usually) and no house payments. One of my houses was a floating model.
Took a week off work to put up more framing:
Still have to frame all the closets and all door rough openings, as well as the kitchen island for the range-oven.
It goes real slow when working alone, plus with the vaulted ceiling have to measure & cut every board individually.
This Tool really helped with accurately measuring all the framing members.
   / Barndominium/Shop or "real" House? #608
Is that plastic under the stair steps? What does it do?
   / Barndominium/Shop or "real" House? #610
So it's temporary?
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A58375)
UNUSED CFG...
2007 Ford King Ranch F-150 (A57148)
2007 Ford King...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
John Deere 6120M (A57148)
John Deere 6120M...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
Steel Work Bench 24" x 60" w/6" Irwin Vise (NO CONTENTS) (A59076)
Steel Work Bench...
