Barn to workshop
/ Barn to workshop
Tractor help 2....
/ Barn to workshop
Instant A/C.....
/ Barn to workshop
From the inside out.....
/ Barn to workshop
I've been busy, really busy the last few days. So here is the update. Last post was shot in the door of the N/W corner of the barnshop. This had the only flooring left in the structure. Unfortunately they installed it sometime after the N wall had settled and pushed out at the base. I raised the wall and leveled it E to W but could not set it vertical as the floor was pushing it out (N).
/ Barn to workshop
I took the floor out in 3 big sections, took a sawzall to the joists and put the forklift under it and lifted. Not quite as easy as that sounded but easier than pulling it one board at a time. This place has so many nails in it if you could put a big enough magnet over it you could lift it. /forums/images/graemlins/grin.gif
/ Barn to workshop
North wall after floor removal, you can see the piers and spacers I used to block it up. The base beam is also 3 seperate sections with an open space instead of 2- 16' sections. I was thinking about keeping an access door here but decided to remove the interior base beams so I will not need outside access on this wall. So I have been hunting for some replacement beams.
/ Barn to workshop
I found 6- 6"x8" beams in the classified 4- 14', 1- 20', 1-22' for 200.00.
/ Barn to workshop
North wall now set on 2 new 16' beams.
/ Barn to workshop
Ran into a little trouble lifting the wall, turns out that the dirt topsoil close to the wall is only a couple inches thick it is still wet sheep stuff underneath. Forklift sank when I was turning it around after lifting the wall. /forums/images/graemlins/crazy.gif
/ Barn to workshop
2615 to the rescue........... /forums/images/graemlins/cool.gif
/ Barn to workshop
Some signs of old age, this is an old insulator for the electrical back in the day. /forums/images/graemlins/shocked.gif
/ Barn to workshop #72
That looks like a mummified bat to the left of the insulator. /forums/images/graemlins/cool.gif
Looks like your making good progress.
/ Barn to workshop
I think thats just a spiderweb, but I did find this (previous owner perhaps).
</font><font color="blue" class="small">( Looks like your making good progress. )</font>
Slowly but surely /forums/images/graemlins/tongue.gif
/ Barn to workshop #74
<font color="blue"> ....but I did find this </font>
YUK!
/ Barn to workshop
I found this today, I know it looks like it is visible. It is behind the N tree and when you are standing you don't see it. So one more to change out........
/ Barn to workshop
Hung 3 new loft beams today, adding another 12 x 24 section.
/ Barn to workshop
These were 4 x 8 inch beams, I notched in 2" on the truss for a little extra support.
/ Barn to workshop
View from on top of beam....
/ Barn to workshop
Closer shot....
/ Barn to workshop
This is the other side of the rotten beam I found today, no apparent damage from the inside......
2017 BOBCAT E50 EXCAVATOR (A65056)
2017 BOBCAT E50...
CHANDLER 500 BBL FRAC TANK (A67714)
CHANDLER 500 BBL...
PILES OF TARPS (DIMENSIONS UNKNOWN) (A68842)
PILES OF TARPS...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
X (A68191)
X (A68191)
2017 VOLVO SD115B PADFOOT ROLLER (A65056)
2017 VOLVO SD115B...
