Barn to workshop
/ Barn to workshop
BillCroasmun,
Thanks, I think that would probably work, just that I am really nervous about picking the whole barn up and undermining, while trying to support it with temporary supports. Thats why I was leaning toward the sunken pylon thing. I could do one at a time, support it on both sides of the digging point remove the existing pier, use PHD, dig in at an angle then move inside and do the same. The ground around the barnshop is really unstable for digging trenches, I dug the trench for the sub panel and the sides just kept collapsing in. Would be a long process as I would have 20 individual concrete jobs essentially.
/ Barn to workshop #42
You might want to look into helical piers. They can be screwed into the ground around the perimeter and the beams can be supported on top of those piers.
/ Barn to workshop
Thanks Ocaj11,
I knew someone would come up with something cool, I'll check'em out.
/ Barn to workshop #44
Larry,
I've been pondering your situation withuot much success.
The joists that are lying down horizontally are acting as your support for your walls. These joists are sitting on dry dirt, or that was the original plan. In some of your pictures there are some concrete blocks built up to support them. I'm wondering if you couldnt dig a footing under them, put in some rebar, with sections of the rebar exposed past the pour, and do it in stages.
They build Hoover Dam in stages, so your barn shouldn't be a problem.
If you go this route, I'd also consider removing those joists all together since the concrete would replace their purpose. You might have to elevate the concret to the bottom of your support beams, but that would be too hard with large sono tubes or wood frames.
Sorry I'm not more helpful. You have a unique situation that is very interesting. Wish I was close just to see it in person.
Eddie
/ Barn to workshop
Hey Eddie,
Attached is a shot of the south wall base.
(I'm wondering if you couldnt dig a footing under them, put in some rebar, with sections of the rebar exposed past the pour, and do it in stages.)
So are you suggesting say, that I dig in between the supports the way it sits now? I guess I had not thought that simply. I had thought about pulling the inner horizontal joists and just sinking a concrete pier under those as the joists don't support anything but the main uprights. But the perimeter joists are supporting wall studs as well.
Thanks for your input it has actually been quite helpful, I wish you could take a look also it always helps to have another perspective.
Thanks again,
/ Barn to workshop
So I got tired of staring at the foundation wondering what I am gonna do so I decided to do a little tractoring /forums/images/graemlins/cool.gif. Here is the before shot.
/ Barn to workshop
This is after about 9 hrs, mostly box blade work with and without the rippers on. I have been needing a place to park everything out of the way so I don't have to keep moving things. Very relaxing, good way to spend some time pondering a problem /forums/images/graemlins/grin.gif.
/ Barn to workshop
Another view,
/ Barn to workshop #49
Larry,
I take back everything I said earlier.
The picture showing the way they built the wall and how its supported really has me wondering why bother with doing anything to it. If it's not broke, don't fix it.
That joist looks totally straight and flat. Anything you do to it will just cause more damage then good.
Eddie
/ Barn to workshop
So you think it would be O.K. without being tied down? It obviously has weathered not being tied down to this point, it just makes me nervous for some reason /forums/images/graemlins/ooo.gif. This was one of the options floating thru my skull, I was thinking that if I left it as it sits I'd still want some kind of floor (I hate working in dirt) I was looking at another project and a guy mentioned Polypavement.com, have you ever had any experiance with it. Looks pretty good on paper and I figure about a 1/4 the cost of trying to slab this place.
/ Barn to workshop #51
I agree with Eddie, if this is even the worst that you have, I would leave it as is. We looked at a place last year with an old barn. If it had been in this condition I would live somewhere else right now. Salvaging this place was the right move, and having it like this to start with is super.
/ Barn to workshop
DannyD,
I wish it looked like this when I started, I spent about a month digging the boulders out from under it and propping it up on piers and blocks. I have replaced a half dozen base beams with RR ties and removed others altogether. Attached is a picture of that wall from the outside before I started this project. Notice the base beam hanging down to the left under the sheet of 4x 8 plywood. Also you can see the height differential from the left corner beam and the right one. If you look at the west wall (camera is shooting south wall) in this picture you can see how the base of the wall follows the contour of the top of the hill. Also if you look at the trees on the right you can see where they were pushing against the roof line forcing the building west. Alot of sweat went into making that wall straight. Thanks for following I hope it is interesting for everyone.
gmsssi,
Thanks somedays I work all day and stop and look around and it does'nt look like I did a thing. your comments help alot...
/ Barn to workshop #54
We love your barn! Keeping it was the right thing to do. I've been involved in a similar project for the last couple of weeks but it involved a pond that everyone had told the customer to remove and replace. We're restoring.
What I'd suggest for the footing support would be to do it a pier at a time.
If your soil is dirt as it appears and not real sandy or pure clay then a little can go along way.
What would be ideal would be to temporary support your beam with blocks so you could drill a pier hole under your vertical support. One of the smartest ideas I've found in the pier industry is the concept of drilling two pier holes with one haunch. Think of the letter A with the cross piece relocated to the top and being your haunch.
Using your three point auger means extra work, a lot of extra work, but it can be done. And based upon your work on this barn up to this point, something you can not only do, but do well.
I'd recommend you find two or three additional augers to convert to extra sections so you can get your holes down to at least ten feet deep.
First I'd drill the hole from the inside. I'd aim it down and towards the outside. When the first flight was down as far as it will go I'd disconnect and add the second flight. When it's down as far as it will go I'd add the third, etc. I use a concrete hoe to pull the dirt or tailings away.
When you're down all the way chances are your tractor won't be able to pull the augers. So you'll probably have to use your big forklift., (btw pallet forks are available at your scrap yards, I usually pay about a hundred or so per pair for the four footers).
Use a plug of some kind to block the hole to keep dirt from falling back in. Then repeat the process from the outside aiming inside. Block that hole. Then dig our a box that sits on top of the two holes. This is your haunch.
Put rebar in both holes and tie it all together with your haunch. Then pour in concrete. Let it cure for a week and then you can jack up your wall to your height you want. If you tied some anchor bolts to your rebar then you can also secure your horizontal beams to the haunch at this time.
The A shape discourages sag and lift. It's really quite ingenous.
Good luck and keep up the good work. And keep in mind that we all have ideas about how to do something. You're the lucky one that gets to pick an choose which ones or combination of those that work for you in your situation.
/ Barn to workshop #55
Larry, great job so far! It's nice to see something old have new life breathed into it. The box blade work really cleans the place up.
What type of floor will you have in the new unit? I see that you are searching for better ways to support the walls. Since you have it proped up already I was curious if you could have someone jack it up some more and pour some curb walls to set the building back down on? They do this with houses and old basements all the time. Then you could finish off with clean slab on the inside, or spread your flooring of choice. Not sure how far you are going to take this project so just throwing some ideas out.
Keep up the good work!
/ Barn to workshop
Wroughtn harv, is this the famous Harvey Lacey /forums/images/graemlins/grin.gif I was just reading your post about being recognized in the restaurant, its tough being famous /forums/images/graemlins/cool.gif
Thanks for taking the time to help out, I really appreciate it. Your haunch method sounds really interesting and I may incorporate a version of that. One of the limitations I have right now is that I don't have anywhere to do any fabrication, also I won't be able to use the welder I have as it is a 3 phase 300 Amp tig and I don't have 3PH here so fabricating the auger extensions would be sometime down the road. Same goes for my pallet fork attachment and quick attach , lot's of things to do and lots of things I want to do now. Thanks again I will be following your pond, somebody was pretty ambitious when they built it originally which is your cool project today /forums/images/graemlins/grin.gif
Tim in IA,
Thanks Tim, the more I get done the more I like this thing. I don't know yet how I am going to finish the base or flooring, getting alot of good feedback and cool ideas. I still have alot to do in other areas so I am letting the base and floor percolate /forums/images/graemlins/grin.gif Take care....
/ Barn to workshop
As I was thinking about what to do with the base and floors today (read procrastinating) I decide to install some air conditioning. 2 prep pics first.... here is the untouched North wall. I was working in the North east corner today.
/ Barn to workshop
After jacking, replacing 2 base beams and blocking...
/ Barn to workshop
attached shed straight on,....
/ Barn to workshop
A little tractor help...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2014 Ford E-350 Cargo Van (A66736)
2014 Ford E-350...
2018 Manitou MLT634 7,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
2012 MERTZ FRAC MANIFOLD TRAILER (A67714)
2012 MERTZ FRAC...
2015 John Deere 319E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
