Ballast Weight Question
/ Ballast Weight Question #21
http://www.palletforks.com/media/catalog/product/cache/1/image/650x650/d9b8a3377680197dfa7fcbba1b0903ed/c/a/cat_1_hay_spear_3_point_attachment_with_sleeve_5.jpg I was thinking of using this bale spear and sticking it in a treated wood box with 2 pcs 4x4 attached to the bottom for skids (pallet forks) sticking a 2" receiver tube out the back, cutting the bale spear to size, do some welding to tie the spears & 2" tube together, tie some rebar together & fill it with concrete leaving the level down about 4" so I'll have a basket for tools, chains, saws, etc... Whadda ya think? The bale spear is rated for 3000#
This is an idea with some merit but, why not buy a Cat 1 trailer mover that already includes the receiver hitch? Should be way less cost than a bale spear?
/ Ballast Weight Question #22
Your owners manuals for the tractor & loader should have the info you are looking for. My NH manuals both state that counterbalance should be used on the rear when using the front loader, and I wouldn't do it without it. That LS dealer is greatly misinformed on this subject. My NH loader manual also states this. (Quote) Sufficient weight can be added to the tractor by filling the rear tires with liquid ballast, or by installing rear wheel weights, or three point counterweight. If three point hitch counterweight is used, carry it low at all times to maximize stability. The effective counterbalance weight of mounted rear equipment is determined by multiplying the actual weight of the equipment by 1.50. EXAMPLE: If equipment weighing 400lbs is attached to the rear of the tractor, multiply 400lbs. by 1.50. This equals 600 lbs. of effective counterbalance weight. To GmanBart. I had a counterweight that was in a vertical configuration similar as yours. The first time I had it on a slight slope of a hill, I thought the tractor was going to turn over, scared me pretty bad. So, I constructed a weight rack that allows suitcase weights to be installed more to the outside of the rear wheels. This greatly increased the stability of the tractor in general. Now, your weight will work fine on level surfaces, but be extremely careful on sloped ground. With the (8) 100lb suitcase weights I have on the rear bracket, I have an effective 1200lbs of rear counterweight. I can add or subtract weight as needed, too...!
/ Ballast Weight Question #23
I added rear wheel weights to the little Yanmar to improve traction rather than as a counterweight. Installing the weight outboard of the wheels (photo) seems to me to be the best location when one goal is to resist rollover. Photo, in use.
For another small tractor that has a loader, I'm considering mounting weights to both the inner and outer edges of the wheels to both improve traction and also counterballast its loader. Photo - prototyping to see if everything fits. For now I'll just use the box scraper for a counterweight but I think I'll go ahead and at least install the outer weight as shown.
2017 BOBCAT E50 EXCAVATOR (A63276)
2017 BOBCAT E50...
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
Ford Metal Tailgate Sign (A64557)
Ford Metal...
2006 Ford Freestyle (A64557)
2006 Ford...
