Ballast / Counterweight
/ Ballast / Counterweight #1
Lunk
Platinum Member
WI
Branson 4720H / BL200 Loader
Hey all!
I have a 3-Point Cat 1 Counterweight that I need to unload. The box is made of 1/8 steel and has internal cross bracing. The top-link mount is welded to the back side of the weight, and it’s about 48” tall.
I put about 28 - 60# bags of concrete in it so it weighs right around a ton. While my 3-point can lift it, it’s way more than I need.
A local welding shop built it for me.
I’m looking for $150.
Located in South Central WI.
Text me at 608-574-4197
Thx
Lunk
Wow, 2x2x4 worth of concrete is about 2400lbs so it looks like it is not full to the top. Is the lift arm rod a full 7/8" of good steel?
Category 1 3-Point Counterweight / Ballast Box - farm & garden - by owner - sale
Yes, it's made with good steel. I paid almost $300 for a local shop to build it, plus the cost of concrete. On my 35hp TYM, it's overkill to the point of rear-axle abuse. It would be awesome for someone looking to do snow removal this winter.
Lunk
/ Ballast / Counterweight #4
Hey all!
I have a 3-Point Cat 1 Counterweight that I need to unload. The box is made of 1/8 steel and has internal cross bracing. The top-link mount is welded to the back side of the weight, and it痴 about 48 tall.
I put about 28 - 60# bags of concrete in it so it weighs right around a ton. While my 3-point can lift it, it痴 way more than I need.
I知 looking for $150.
Thx
Lunk
Wow, Lunk! Your front tires probably barely engage the ground! Not safe unless you have something really heavy on the front to counterweight your counterweight!
I bought a Titan ballast box and modified it. Probably weighs about 600 lbs. I've attached a few pics of it and here's a link to a playlist that includes Part 1 of a video on how I modified it. Part 2 is coming soon. A Ballast Box for My Kubota - Part 1 - YouTube
/ Ballast / Counterweight #5
I just use one of my implements like my tiller when I need a counter weight.Saves a lot of time and money. I also have loaded rear tires.
Hope this helps
/ Ballast / Counterweight #6
I almost alway have my heavy duty rear blade on. Either the rear blade or some other implement. I also have 1550# of Rim Guard in the rear tires.
