Surprised by need for rear ballast with L 4060 in this situation
   / Surprised by need for rear ballast with L 4060 in this situation #41
So legitimate question and I'm not tractoring so may as well get smarter.
So tape measure says my pins on the 3PT are 31 inches behind the axle (give or take me trying to look at two round objects things 31" apart and measure them). Wheel base is 84". So a handy calculator puts it at 10lbs on the 3PT (at the pins) lifts up on the front axle 3.7 lbs so 37% of the weight (at the pins) transfers off the front axles? Not bad. I don't have any ballast boxes so I'm sure all my implements push that ratio even higher pound for pound.
The front axel makes no difference. You need to measure from the load that’s on the FEL to the back axel. It’s probably another 6 feet out for a 2’ on center load.
   / Surprised by need for rear ballast with L 4060 in this situation #42
You didn’t do the math right for starters. The front axel makes no difference. It’s the distance the load on the loader is front of the rear axle that makes the difference. And you along with nearly everyone else are ignoring how much more the loader can lift with ballast vs without. Again I’m not saying not to use ballast it’s essential.
The amount in the loader doesn't make any difference in how much ballast behind the rear axle affects the front wheels. You could lift up 2oz on the front axle with ballast then lift 7 million pounds and the ballast is still relieving 2oz of weight from the front axle.
   / Surprised by need for rear ballast with L 4060 in this situation #43
That's not how physics works. Granted this is more like a plane and finding a center of gravity but the 3PT's fulcrum is generally the rear axle and the FEL fulcrum is generally the front axle.
   / Surprised by need for rear ballast with L 4060 in this situation #44
I’m not a fan of lawsuits but they’re about right this time. A tractor with a loader is one of the few things that isn’t safe to be used as intended the way it’s sold. That’s kinda like selling a vehicle without a hood latch and saying if you want to drive over 5 mph you have to add that separate.
I know. Anyone that knows me knows I am NO fan of the tort lawyer, BUT in this case if someone had just taken the time at the dealership to warn this individual (however ignorant he may be) about the dangers of using the bare tractor without any ballast and insisted on selling him at least a ballast box and at least talking to him about loaded tires or wheel weights he might still be alive. In the big scheme of the tractor purchase even for a low end tractor like the 3038e, the additional couple hundred bucks for a stinking ballast box might have saved him. At least he would have had the chance to think a little about it.
We don't know what exactly happened and under what circumstances he rolled his tractor over. I can guess. My guess would be he lifted a load with the FEL, and he had the loader bucket well above the hood of the tractor like all NEW tractor owners do (because they are ignorant of the dangers) and he turned the tractor on slightly uneven ground or the high side tire found a protruding rock or the low side tire found a hole and the tractor overturned. He probably wasn't wearing a seat belt, and we don't know about the ROPS, but in any case he became trapped under the tractor and was crushed.
How many pictures of rolled over tractors have we seen here on this forum? Plenty, that's how many. And where is the loader bucket in relation to the hood of the tractor? Well above it in almost all cases. I grew up as a child around tractors and machinery, and had a pretty good idea of how to stay safe around them, but even I had a few close calls. I never rolled one, but I sure had the rear tires come up off the ground because of improper ballasting. Lessons learned, don't do that again.
   / Surprised by need for rear ballast with L 4060 in this situation #45
You’ve changed the measuring terms. Lifting up 2 oz on the front axel is a clear cut story. It’s 2oz lighter than it previously was. But for calculating how much a given amount of ballast lifts the front axel the position of the front axel is irrelevant. You need to know how far the ballast is behind the front axel and how far the load is in front of the rear axel.
   / Surprised by need for rear ballast with L 4060 in this situation #46
Really?
   / Surprised by need for rear ballast with L 4060 in this situation #47
   / Surprised by need for rear ballast with L 4060 in this situation #48
I can tell you this much, there isn't going to be any Deere tractors sold in the future without there being a ballast plan conversation in the future. Other brands would be wise to take notice.
Last week, a Payne County jury awarded a Stillwater woman $5 million in a civil suit that followed her husband's death in a tractor accident.
The jury found Deere & Company, the manufacturer of John Deere tractors, to be responsible for the May 25, 2014, death of James Beall, age 38, of Stillwater, when the tractor he was driving rolled over, trapping him underneath. Shylah Beall, his widow, was represented by Smolen Law, a Tulsa firm.
The case involved a John Deere 3038 E Compact Utility Tractor with a 305 front loader that was sold to the Bealls by P&K Equipment, Inc., of Stillwater. The tractor and an optional front loader were assembled at the Deere plant in Georgia and then shipped to P&K Equipment.
Shylah Beall's suit claimed that the tractor was unsafe and had not been properly configured by either the factory or the dealership before she and her husband took delivery. Throughout the lawsuit, Deere denied the accusations.
Beall's attorneys said Deere’s manufacturing failed to add additional weight to the rear of the tractor to counterbalance the almost 700-pound front-end loader, before it left the Deere plant in Georgia. The weight was also not added at the local dealership.
Representatives of Deere & Company said the tractor was not defective or unreasonably dangerous and suggested Beall may not have been wearing his seatbelt.
During the trial, the representative for Deere & Company admitted that ballast is supposed to be added to the rear and tires of the tractor. In the instruction manual it said, "To prevent death or bodily injury from tractor loader roll-over, the required amount of ballast must be added to the tractor."
The proper ballast wasn’t added before Beall bought the tractor, and Beall's attorneys argued that evidence shown during the trial suggested that if the weight had been added as recommended, the tractor wouldn’t have rolled over.
Carlton Hearn, a product safety engineer for Deere & Company, testitfied that the tractor was supposed to be configured ready for use at the dealership, and there is a checklist dealers go through to ensure a tractor is ready for use.
Among the checklist items was the installation of ballast to to prevent rollover and injury. At first, it seemed the Hearn was suggesting that it would be up to the consumer to do whatever needed to be done with the tractor, according to a transcript provided to the News Press by Smolen Law.
"So let me ask you this, so when James and his dad, Clyde, showed up to P&K and they – and he had this dream of having his own business and he had this 16-acre property that he needs help mowing," attorney Donald Smolen asked. "You think that they should have thought to themselves, 'Hey, even though I'm buying this thing brand new from John Deere and it's come directly from the factory all set up, I bet it's in an unreasonably safe condition and that I need to go through and make sure that they did everything they are supposed to. Is that the way that Deere sells its equipment?'"
"I'm sorry. What way?" the rep asked.
"Well, you've got here that in order for this tractor to be safe, and properly weighted, and properly ballasted there are certain things that have to be done to the tractor when used with a loader right?," Smolen replied. "I mean, that's what we have been talking about. And these things that are listed, the consumer, James Beall, Clyde Beall, me whoever, the consumer can't even do that, they can't even install the rear tire weights according to Deere, right?"
"It's recommended that they are done by a Deere dealership," Hearn replied.
On Jan. 16, a Payne County jury found after 27 minutes of deliberation that "by clear and convincing evidence that the defendant, Deere & Company, acted in reckless disregard for the rights of others." They awarded Shylah Beall $3 million in actual compensatory damages and $2 million in punitive damages.
In a statement released Thursday, Shylah Beall said that her main goal was to hold the company accountable and make sure nothing like this happens in the future.
“I don’t want James’ death to be in vain,” she said. “I want proper safety protocols followed in the future.”
Attorney Donald E. Smolen, II, said the compensation will help Shylah raise her young son, who is now left without a father.
“No amount of money will take the place of a loving husband and father, but these funds can help Shylah and her family in other ways,” he said. “Our greatest hope is we can prevent this from happening to another family. We are pleased the jury decided in our favor.”
Getting a jury to side with a plaintiff against a large corporation is one thing. Having such judgment hold up on appeal is quite another. Unless and until it does, any precedential value is negligible.
I expect that the buyer was offered rear ballast but declined. I also expect that he was not wearing his seat belt. Of course any question not raised at trial level cannot be raised upon appeal.
Tough facts often result in bad (common) law.
Only time will tell.
SDT
   / Surprised by need for rear ballast with L 4060 in this situation #49
In my case every 10lbs I lift at the pins on my 3PT makes the front axle ~3.7lbs "lighter". Regardless of how much you push down on the front axle, it's pushing up ~3.7lbs.
   / Surprised by need for rear ballast with L 4060 in this situation #50
You’ve calculated wrong. Say you take a board that’s 3 feet long and you put a pencil under both ends 1 foot from the end. You’ve got 1 foot from each pivot to the end and you’ve got 1 foot between the pivots. That’s our tractor with ballast hanging off one end and a loader off the other. You put a 1 pound weight on both sides of the board. Excluding the weight of the board each pencil is supporting 1 pound. Now you put another 1 pound weight on one side. Under your logic the board should now be totally balanced on the one pencil. Its not because the weight is farther out than the pivot. It only lifts 1/2 pound off the pencil for every pound you put on the opposite side.
1999 Triton boat with trailer (A55853)
1999 Triton boat...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A57880)
2020 FREIGHTLINER...
1998 John Deere 7410 (A53317)
1998 John Deere...
2011 JCB 3CX (A53317)
Caterpillar Quick Attach Forks (A56469)
Caterpillar Quick...
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
