Ballast ballast box weights?
/ ballast box weights? #1
hanson1999
minnesota
JD
I am going to get the jd ballast box for my 2520. if filled with concrete anyone know how much it would weigh?? or filled with gravel?? i am hoping to somehow get around 800 pounds of weight on the back.
/ ballast box weights? #2
My situation was this: I had (7) 42 lb suitcase weights for the front and a ballast box. I wanted some removable weight for the box so I wouldn't have to use the full amount of weight all the time.
So, I put (4) 80 lb bags of concrete in the box which left just enough room for the cast iron weights to sit in the top. Now, I have a box that weighs about 473 lbs without the cast iron and 809 lbs with (8) suitcase weights (I bought an extra one because I had room in the box for it).
runner,
that looks great just what i'm lookin for, did u buy bags of quikcrete and just mix it up right in the box?? that sounds almost to simple!!
/ ballast box weights? #5
hanson,
Well, kind of a long story. I had a couple of bags of quickcrete sitting around that had partially hardened up and I didn't know what to do with them. So, I got the bright idea to use them in the ballast box. I knew two bags wouldn't be enough weight, so I bought two new bags.
However, I didn't want to have a permanent fill in the box, so I decided to line it with a couple of layers of sheet plastic. This also sealed up the box so that the liquid from the wet concrete would not seep out the seams.
So, the way I filled it was, put in the plastic liner, then, alternated layers of the old hardened up quickcrete (crunched up with a sledge hammer) with layers of wet mix (mixed in a wheel barrow) with plastic sheet in between.
This way, I figure that I can remove the concrete in the future if I want to by just smacking it with a hammer and chisel to break up the layers. However, in reality, I will probably never remove it.
Once I got the top layer of wet mix in, I smoothed it out with a trowel and made sure it was level. The four bags filled it just enough to leave room for the cast iron weights in the top.
The other thing I like about this solution is that it gives me a great place to store the cast iron weights which I don't use all that much otherwise.
On edit, I noticed that I wrote that I had 473 lbs of weight in the box with 4 bags of quickcrete which was a mistake. I think the number is more like 437 lbs with just the concrete and 809 with all of the weights.
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2023 JCB 3TS-8T TELESKID (A65053)
2023 JCB 3TS-8T...
2019 Nissan Kicks Hatchback (A66738)
2019 Nissan Kicks...
PORTA POTTY (A67714)
2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
2023...
