Dirt Moving Ballast box on B3200
/ Ballast box on B3200 #1
critter986
John Deere 345 & Kubota B3200 FEL
I have a kubota B3200 and im not sure what to put in the ballast box while im moving dirt. I had 2 5 gallon buckets filled with dirt but i think i could have more weight. What do you think the best thing to put in there would be?
/ Ballast box on B3200 #2
I built a carry all box for my 3200 when I had it. I could put whatever I wanted in it for ballast. Concrete blocks, firewood, bags of sand, etc. You need something bigger then 2, 5 gallon buckets. They won't hold enough weight to maximize the power potential of your tractor. I used on average about 600 pounds for ballast.
/ Ballast box on B3200 #4
I use nine 50# bags of pea gravel that I picked up at the local home store. This plus the weight of the box I figure I have close to 550#
/ Ballast box on B3200 #5
I use 4"-6" rocks, then the weight can be adjusted as needed easily.
/ Ballast box on B3200 #6
I filled mine permanently with portland cement. Figured I didn't need to use my ballast box for anything other than ballast.
/ Ballast box on B3200 #7
This is what I use.
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
4 Bottom Plow (A65640)
1350-gallon Liquid Tender / Nurse Trailer (A66285)
1350-gallon Liquid...
Jobox Truck Bed Tool Box (A64556)
Jobox Truck Bed...
2020 Patriot 12' Enclosed Trailer (A66285)
2020 Patriot 12'...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
