Dirt Moving Ballast box on B3200
/ Ballast box on B3200 #1
critter986
John Deere 345 & Kubota B3200 FEL
I have a kubota B3200 and im not sure what to put in the ballast box while im moving dirt. I had 2 5 gallon buckets filled with dirt but i think i could have more weight. What do you think the best thing to put in there would be?
/ Ballast box on B3200 #2
I built a carry all box for my 3200 when I had it. I could put whatever I wanted in it for ballast. Concrete blocks, firewood, bags of sand, etc. You need something bigger then 2, 5 gallon buckets. They won't hold enough weight to maximize the power potential of your tractor. I used on average about 600 pounds for ballast.
/ Ballast box on B3200 #4
I use nine 50# bags of pea gravel that I picked up at the local home store. This plus the weight of the box I figure I have close to 550#
/ Ballast box on B3200 #5
I use 4"-6" rocks, then the weight can be adjusted as needed easily.
/ Ballast box on B3200 #6
I filled mine permanently with portland cement. Figured I didn't need to use my ballast box for anything other than ballast.
/ Ballast box on B3200 #7
This is what I use.
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
INOP/NON- RUNNING Kawasaki 550 Mule (A65579)
INOP/NON- RUNNING...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
DMI Tiger-Mate Field Cultivator Hitch (A65640)
DMI Tiger-Mate...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
