ballast box for Deere 855 CUT
   / ballast box for Deere 855 CUT #41
How much do you figure your ballast box weighs with sand?
This is an estimate based upon the volume, but I'd estimate between 600-700 lbs. Quite adequate for my needs. I use it for added traction and the occasional heavy lift...but I doubt I've ever lifted anything even close to the loader's capacity. Recently, the heaviest thing I've lifted has been a 650 lb rotary cutter...and the counterweight was as much for the length of the cutter (extends way out in front of the bucket) as the actual weight of the cutter.
   / ballast box for Deere 855 CUT #42
I finally got around to looking up the weight of my BB. It is 465lbs. I added to that 160lbs. of railroad steel over the cutting edge so that makes it 625lbs. with a bias towards the rear of the BB. Add to that 380lbs. of liquid ballast in the rear tires and I can max out the lifting capacity of the loader without lifting a rear tire.
   / ballast box for Deere 855 CUT #43
I don't know how much the #7 backhoe weighs, but at the rather tall height of my truck bed, the loader booms would not lift the backhoe, but a slight curl of the bucket lifted the backhoe off the bed of the truck so I could carefully back the tractor to clear the truck bed. No problems with lifting a rear tire and was stable and comfortable throughout the unload.
CAT 930M (A58214)
CAT 930M (A58214)
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
(12) WOOD PALLETS (A60432)
(12) WOOD PALLETS...
Year: 2012 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A59230)
Year: 2012 Make...
TANK MANIFOLD (A58214)
