bad alternator?
/ bad alternator? #41
You don't say where in northern Vt. you are, but there's a pretty good starter/alternator shop in St. Johnsbury just off Portland St. I've used them a couple times, prices are reasonable and turnaround is quick. The owner may be able to assist you with troubleshooting.
/ bad alternator? #42
The connecter of the posts on your regulater should be marked with a letter (B,A F,G). What are they on yours?
Also how many wires are coming out of your alternator and regulater?
If we can find which wire exites the stator in the alternator you can put battery voltage to it with a jumper wire. If the alternator work with the jumper then it's OK and your problem is the regulater or the wiring.
Note: A 1924 Dodge does not have a regulator.
Sunflower 1234 (A64126)
Sunflower 1234...
Pallet Forks (A64127)
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
John Deere TX Gator (A60462)
John Deere TX...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
