bad alternator?
/ bad alternator? #21
The connecter of the posts on your regulater should be marked with a letter (B,A F,G). What are they on yours?
Also how many wires are coming out of your alternator and regulater?
If we can find which wire exites the stator in the alternator you can put battery voltage to it with a jumper wire. If the alternator work with the jumper then it's OK and your problem is the regulater or the wiring.
/ bad alternator?
in order to get to the regulator we have to remove the fuel tank. we ran an "N" circuit voltage test on the alternator per the repair manual:
  • connected the volt meter red lead to the N terminal on the alternator
    connected the volt meter black lead to the ground of the battery
    with the engin at 1500 RPMs the volt meter reading was 0.17
according to the repair manual this means we have a faulty alternator. can anyone confirm this?
if the tractor is jumpable is there anything bad with using the tractor by jumping it untill we are able to get a replacement alternator?
will the tractor stall in the woods? will we cause damage to the tractor by doing this?
Thanks for the input
/ bad alternator? #23
moojambo if you would call dan smith 617-680-1557 he is boston ma. but he has covered the northeast for years he is alternator/starter rebuilder he can help you through this and also put you in touch with a builder closer to you than can solve your problem and i am firm beleiver if a starter or alternator or generator can be fixed or rebuilt it is very highly a better product than you can buy in todays market this is his cell number just let him i gave it you. one simple test to see if the alternator is working is to put in on test stand and hook up to the post on back of unit it should go to full field which means the charging will be wide open if it is working correctly on 6 volt system will probably go as high as 9 volt then you shut it down as not to do any damage to unit also on the 12 volt it will go as high as 15 to 16 volt also shut down this will help you rule out one or the other of alt to regulator
/ bad alternator? #24
on further research see if this is what you have your ford tractor has a japanese built 3 cyl motor built by shibaura if this is correct your alternator is hitachi number lt135-27 if this is correct the plug in on the back of your alternator is shaped like a "T" the top spade is the "N" the up and down one is the field this is where the power would come from back to the first reply i did if you have away to spin alternator even on the tractor with the regulator disconnected hook volt meter to the "F" spade and make sure it has good ground at this point the alternator should go to full field and top out about 15 volts it is non regulated with regualtor not hooked up let us know how this works if regulator is problem again dan smith in boston can help you with this
/ bad alternator?
So we got the alternator and regulator tested. the regulator needed replacing and the alternator had bearings and brushes replaced. hooked everything back up with a new battery.... get 12.6 Volts from the battery while tractor off. turn the tractor on to 1500RPMs and still only get 12.6Volts. any ideas where the problem might be? the manual says the only way to test the alternator is to have a load tester. is there another way to see if the alternator is putting out the right voltage?
/ bad alternator? #26
did you try to check alternator with regulator disconnected it should take the volt meter well past 14.5 in just a few seconds as i stated before this is called full fielding which implies the voltage is non regulated and will actually go till it pops a diode in the rectifier now on another point i would say the 12.6 voltage is actual battery power only and a no charge from alternator you possibly have a bad rotor which is the first part of the alternator to create power it is not uncommon for them to quit working do you remember what the slip rings looked like when unit was apart this is where the brushes run in the alternator
/ bad alternator? #27
i'd have that reg and alt tested again!
/ bad alternator?
the alternator was just bench tested at a local place which rebuilds alternators as a business. while they were testing the alternator they replaced the brushes and the bearings. they said that the alternator bench tested good and they recommended we look at the regulator. the regulator they said was bad and they sold us a replacement regulator which is a non-mechanical regulator (electronic).
we ran the tractor with the regulator disconnected. the voltage never got above 12.67 volts. we checked the continuity of all circuits between the regulator and the alternator and the continuity of the regulator and seems that the resistance is low or none for all of these.
the local shop says that the alternator is good. they said they will make a visit to our house to look at the tractor for a fee including travel time. is there a way we can independently confirm the alternator is good prior to having them come to the house? This is our first time using this company and with all the other testing we have done we question if this company is trying to get more money out of us or if the really did test the alternator correctly. They are the only company around which does this work and they were recommended by a local repair shop.
/ bad alternator? #29
can they not test the reg and the alt on their own bench?
if it tests good on their bench.. go home.. hook it up not using the wire harness.. hook it up with jumper wires point to point, with charge wire straight to battery.
test battery first. a bad cell will pull down 2v and work the p!ss out of the alt..
once hooked up straight.. run it and check volts. it SHOULD work that way if it works on their bench AND the bat is good, AND you have no dead shorts that glow red and smoke when running...
post back
/ bad alternator?
how would you hook up the alternator without the wiring harness? we have an alternator which looks like this
which connectors do we hook up to battery positive? negative?
/ bad alternator? #31
just make up some jumper wires with proper terminals and plug them in singally not using the plug/harness. you can look at the harness at the vreg and the plug to figure out what goes where.
/ bad alternator?
The B terminal will go to battery positive but where do the N, E and F terminals go? the wiring diagram isn't that clear to what goes to Ground. at the moment the positive battery terminal is hooked up through the starter to the B terminal and then the N,E and F terminals all go to the regulator and then from there i assume they some how find their way back to the battery but i'm not sure. any help would be appreciated. i can post the wiring diagram if someone could help.
thanks.
/ bad alternator? #33
not sure about the 'n' plug but the 'e' plug is the ground to regulator 'e' basically means earth ground external ground as well as others the 'f' is the field this is going to pass power from regulator to alternator and reverse again as soundguy stated just make jumper wires from one to the other and test this away also with volt meter with tractor running by touching the 'f' and 'e' should test unit as to full field and go into overcharge post back what happens
/ bad alternator? #34
/ bad alternator? #36
Not sure about yours but most alternator i've worked with have internal regulators so you'd be looking at rebuild/replace.
I was recently surprised to learn that (EDIT: some? not all? not sure) motorcycles have a separate stator and rectifier/regulator, instead of an all-in-one alternator. I had only encountered alternators before.
/ bad alternator?
Lessoned learned... when trying to diagnose charging system issues make sure your key is in the on position. our tractor will run untill the engin is choked out no matter if the ignition switch is on or off. we got in the habbit of turning the key off and even taking it out of the ignition to make sure the battry didn't get left on to save the battry. low and behold this does not allow the regulator or the alternator to supply charge to the battery so you are always running off battery power and very hard to diagnose charging issues. we did however discover that the regulator was bad. the alternator is good and everything was working fine while in the shop.
new issue. the battery indicator light glows at 1500RPMs or bellow but not when the RPMs are above 1500...what might be causing this? is the new regulator not working propperly? did the alternator have something go wrong with it while testing all the other issues?
thanks for everyones help.
/ bad alternator? #38
check charge voltage above and below 1500 rpm.
yer oil lamp won't work when the key is off either so iw ould not reccomend doing that!
/ bad alternator?
the voltage from 1000rpms to 2200 rpms is 14.45 to 14.51volts. but the indicator light will flash bright and slow at 1000rpms and rapid and less dim all the way up to 2200 rpms. the light is not on when the tractor is first on the light does not flash but while the tractor runs the light will be on for higher and higher rpms. but the voltage at the battery still reads 14.45 to 14.51 even after the tractor being on for an hour.
should the light worry us? the alternator is rebuilt, battery new, and the regulator is new.
/ bad alternator? #40
if the voltage is correct.. you are fine.
the light flashing must be a cluster issue.. perhaps a chaffed wire or blocking diode failing.. maybee even a power issue with t he cluster.. / key switch possible too.
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
2010 GMC 3500, Crew Cab, 2WD, Dually (A62679)
2010 GMC 3500...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
John Deere 7R 210 (A64126)
John Deere 7R 210...
2013 Kobelco SK26LC (A64126)
2013 Kobelco...
