backup alarm modification
/ backup alarm modification #1
disney
orlando fl
scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
How many of you have disconnected the back up alarm horn/buzzer because you (your wife, neighbors, etc) find it annoying? Ever wish you had a horn to get someone's attention when they are out of shouting range? Maybe even wish once in a while that the back up horn was still connected? Here's an easy fix. Install an on/off/momentary switch so you can have the alarm work like normal in reverse (on position), be quiet (center off position) and function as a horn only as long as you push the spring loaded switch lever (momentary position). Switch was less than $10 (for a 3 pack) on flea bay, a few more dollars for the rubber cover, and most everyone should have some solder, or connectors around the shop.
/ backup alarm modification #2
Don't have a backup alarm on my tractor.
And when the seat switch failed, it was faster and cheaper to insert a jumper into the plug ends than it was to replace the seat switch.
I'm always belted in, so I never have to worry about falling out of the tractor and getting run over.
And I make it a habit to always stop, throttle down, and engage the brake before exiting the seat if I have to leave the tractor running.
/ backup alarm modification #3
MY backup alarm has an ON-OFF switch. It is normally OFF unless other people are going to be nearby. Then it's ON.
If I did not have a horn too, I would consider your idea, it's a good one.
/ backup alarm modification #4
Thanks...An idea worth the effort (just to have). I disconnected the back up alarm on our golf cart about 12 years ago and never thought about it since...I think I will add a switch...probably when I get around to putting some (head) lights on it...been on the "to-do" list for almost 12 years...so it shouldn't be too much longer...I'm a multi-tasker...!
/ backup alarm modification #5
This is a good idea. I may go back and do this.
I disconnected the wiring from the audible beeper and put small strobe lights in the rear of the tractor.
I figured it was a compromise.. the neighbors are happy, my ears are happy and the strobes will hopefully catch someones attention if I'm backing up close to them.
New Holland 565 Square Baler (A64047)
New Holland 565...
1770 (A58375)
1770 (A58375)
2012 DRAGON  130BBL VACUUM TRAILER (A63569)
2012 DRAGON...
2017 International 4300 Box Truck (A62613)
2017 International...
60� Drum Mulcher (A64047)
60� Drum Mulcher...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
