disney
Gold Member
- Joined
- Aug 11, 2012
- Messages
- 381
- Location
- orlando fl
- Tractor
- scag turf tiger 61" #2, gx95, sold f525 twice, f725 sold
How many of you have disconnected the back up alarm horn/buzzer because you (your wife, neighbors, etc) find it annoying? Ever wish you had a horn to get someone's attention when they are out of shouting range? Maybe even wish once in a while that the back up horn was still connected? Here's an easy fix. Install an on/off/momentary switch so you can have the alarm work like normal in reverse (on position), be quiet (center off position) and function as a horn only as long as you push the spring loaded switch lever (momentary position). Switch was less than $10 (for a 3 pack) on flea bay, a few more dollars for the rubber cover, and most everyone should have some solder, or connectors around the shop.
