Backhoe BACKHOES LETS SEE THEM
/ BACKHOES LETS SEE THEM #62
Kioti CK20S with a well used 2465 Backhoe and home made thumb.
/ BACKHOES LETS SEE THEM #63
Mahindra 2816 gear with a 3710 backhoe. Just wish I had a thumb!
/ BACKHOES LETS SEE THEM #65
/ BACKHOES LETS SEE THEM #66
I have a shiny new KWIK-WAY Dirt Master. So far I have just dug out a few trees with it.
3v0,
When you are running that neat, little, Dirt Master, does it pull itself around, or do you have to get off and move it yourself?
hugs, Brandi
Jt42 what kind of motor runs it and it HP? And what size pump do you have on it? Also is this machine worth the cost and efforts it took to build it?
/ BACKHOES LETS SEE THEM #69
hugs, Brandi
With enough practice one can move it. I can move it forward and back and a bit side to side. With something like trenching self motivation would work well. To move around a stump it is easier to hook it up and move it.
/ BACKHOES LETS SEE THEM #71
Very nice indeed. Also nice to see I am not the only one here with a towable.
i considered a towable.. ended up finding my 3pt at an auction for such a good deal, couldn't pass it up
/ BACKHOES LETS SEE THEM #72
No the thumb has never moved on me. I check the bolts on a regular basis to ensure security.
The interior shots are my cottage renovation. Contractor raised the cottage and doubled it in size, adding a full basement. I am removing fill after the building was set down on the supporting walls. We ran into bedrock under the old portion and had to drill and use expanding powder to break the rock. Then the backhoe was used to remove the rock.
Surprised there are not any on here that attaches to the skid steers!
/ BACKHOES LETS SEE THEM #76
GregbkH, is that a 758 BH on your 3045 and who makes the bolt on thumb? Thanks, Bill C
/ BACKHOES LETS SEE THEM #78
How long and how hard is it to remove or put on the backhoe attachment? In case you might need to use a bush hog or other type of implement. Lets say it is attached to a Kubota L series or something similiar.
/ BACKHOES LETS SEE THEM #79
I have a Kioti DK with a Rhino backhoe.
Takes me less than 5 minutes to remove my backhoe.
Around 10 minutes to install.
That's not bad at all! Takes me about thirty mins to put the attachment on my 706 only done it 3 times tho! I'd say with a little practice is get better at it tho!
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
iDrive TDS-2010H...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
