Backhoe
   / Backhoe #1
Brenka
Case Jx 85 and Farmall 80, MF 165
I have a farm tractor backhoe with PTO pump and oil tank.
Can I remove the pump and quick connect the hoses to the tractor power beyond. ??
Or I must remove the oil tank. ??
   / Backhoe #2
Why do you want to? Right now your tractor is a sealed system, and the BH is another altogether different system. Why risk cross contamination?
   / Backhoe
I agree with you about the contamination, this was a concern I had in the back of my mind. On the other hand, the pump is aging. I tought this will simplify my hook up.
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
48ft all aluminum feather light wedge trailer (A56436)
48ft all aluminum...
5004 (A55851)
5004 (A55851)
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
