Backhoe
/ Backhoe #1
currierej
Newalla, OK
Yanmar 1810D
I just bought a backhoe, it is setup with a homemade bobcat adapter, I'm going to be converting it to 3 point, is there any things that I should add or consider to make it work better?
/ Backhoe #2
I would suggest you might want to consider a subframe. A hoe really puts a lot of stress on the tractor. Try this post if you are interested in tackling it. Dfkrug is a friend, an engineer, and a talented fabricator - he used to sell TPH hoes but fabricated subframes for his customers. I've had two CUTS with hoes, a B21 Kubora and my LS 3038H and both come with subframes.
Of course you will need rear remotes or at least hoses to connect your hoe to the hydraulics - but you know that.
I love having a hoe - it is not something I use often but when I need to dig, that is the shovel I go for. I have replaced two septic leach fields with my little hoes saving thousands of dollars over having it done so they do pay to own.
/ Backhoe
I'd like to build a subframe, just not sure how to go about it and what it should incorpperate
/ Backhoe #4
If a subframe is too much look at Kubota's 3-point hitch saf-t-lok
solution and get a beefed up top link and bars from the 3 point arms to the top-link.
/ Backhoe #7
That saf-t-lok may help protect the operator, but ti does nothing to protect the tractor from the stresses a backhoe can put on it. Some tractors are designed to handle that, but the vast majority of today's CUTs are not.
2024 CHUBBS GT-612/60 1T/A 12FT DUMP TRAILER (A67148)
2024 CHUBBS...
2003 Ford Winstar (A64557)
2003 Ford Winstar...
(10) UNUSED SDLANCH RS3803-1.5" RATCHET STRAPS (A65055)
(10) UNUSED...
2619 (A65055)
2619 (A65055)
2017 Ford F-450 Crew Cab Mason Dump Truck (A64556)
2017 Ford F-450...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
