Backhoe
/ Backhoe #1
currierej
Newalla, OK
Yanmar 1810D
I just bought a backhoe, it is setup with a homemade bobcat adapter, I'm going to be converting it to 3 point, is there any things that I should add or consider to make it work better?
/ Backhoe #2
I would suggest you might want to consider a subframe. A hoe really puts a lot of stress on the tractor. Try this post if you are interested in tackling it. Dfkrug is a friend, an engineer, and a talented fabricator - he used to sell TPH hoes but fabricated subframes for his customers. I've had two CUTS with hoes, a B21 Kubora and my LS 3038H and both come with subframes.
Of course you will need rear remotes or at least hoses to connect your hoe to the hydraulics - but you know that.
I love having a hoe - it is not something I use often but when I need to dig, that is the shovel I go for. I have replaced two septic leach fields with my little hoes saving thousands of dollars over having it done so they do pay to own.
/ Backhoe
I'd like to build a subframe, just not sure how to go about it and what it should incorpperate
/ Backhoe #4
If a subframe is too much look at Kubota's 3-point hitch saf-t-lok
solution and get a beefed up top link and bars from the 3 point arms to the top-link.
/ Backhoe #7
That saf-t-lok may help protect the operator, but ti does nothing to protect the tractor from the stresses a backhoe can put on it. Some tractors are designed to handle that, but the vast majority of today's CUTs are not.
CATERPILLAR 525B DUAL ARCH SKIDDER (A64276)
CATERPILLAR 525B...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
2021 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2021 ASV RT-25...
UNUSED WOLVERINE TDB-11-72W-72" BUCKET (A64281)
UNUSED WOLVERINE...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
8' DISC HARROW (A60430)
8' DISC HARROW...
