Backhoe backhoe
/ backhoe #1
garydc
Kawartha Lakes, On.
Kioti ck20
finally got my backhoe mounted onto the ck20 I brought home about a month ago. bought the rear remote kit and the subframe from my local kioti dealer and installed the remote did a little mod work to mate the hoe to the frame this weekend. hope it works as good or better then it did on my old kub. b6200.
Gary
/ backhoe #2
Looks pretty good! It's nice to see it on a full subframe instead of a 3pt mount, that will surely help with the strength of the unit. Looks like that seat with have you sitting pretty high up too which may be a good thing.
/ backhoe #3
Nice job on the backhoe adaptation.
Get that guy with the greasy pants off your nice new tractor. :D
I cannot see from the photos if you have the loader fix kit installed. Looks like the KL120 rather than KL120B so you might want to double check on that.
/ backhoe #4
If you look in the 3rd picture, you can see the bolts of the kit. You old guys need new glasses...:eek: :D :D
/ backhoe
Thanks guy's, I think the subframe will be a real bonus although the hoe was on the three pt. hitch on my b6200, it had bracing from the loader to the rearend to reduce flexing, I never had any problems with breaking the tractor. but i was allways concerned, again I think the frame will be better. the seat height is comforable and the whole thing only measures about 2 " higher overall on the ck20 than on the 6200.Just a bit of welding and drilling to fit the frame to the hoe. All told I spent about 1/2 a day each sat & sun to do the job including the remotes. and yes the loader has the update. Oh and it was either the guy in the greasey coveralls or the wife, and I might lose the tractor to her if I had done that.
Gary
2022 EZ-GO ELITE...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
KMC 3376 (A64126)
KMC 3376 (A64126)
2008 PRESVAC HYDRO BLASTER (A59914)
2008 PRESVAC HYDRO...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
