Backhoe backhoe
/ backhoe #1
garydc
Kawartha Lakes, On.
Kioti ck20
finally got my backhoe mounted onto the ck20 I brought home about a month ago. bought the rear remote kit and the subframe from my local kioti dealer and installed the remote did a little mod work to mate the hoe to the frame this weekend. hope it works as good or better then it did on my old kub. b6200.
Gary
/ backhoe #2
Looks pretty good! It's nice to see it on a full subframe instead of a 3pt mount, that will surely help with the strength of the unit. Looks like that seat with have you sitting pretty high up too which may be a good thing.
/ backhoe #3
Nice job on the backhoe adaptation.
Get that guy with the greasy pants off your nice new tractor. :D
I cannot see from the photos if you have the loader fix kit installed. Looks like the KL120 rather than KL120B so you might want to double check on that.
/ backhoe #4
If you look in the 3rd picture, you can see the bolts of the kit. You old guys need new glasses...:eek: :D :D
/ backhoe
Thanks guy's, I think the subframe will be a real bonus although the hoe was on the three pt. hitch on my b6200, it had bracing from the loader to the rearend to reduce flexing, I never had any problems with breaking the tractor. but i was allways concerned, again I think the frame will be better. the seat height is comforable and the whole thing only measures about 2 " higher overall on the ck20 than on the 6200.Just a bit of welding and drilling to fit the frame to the hoe. All told I spent about 1/2 a day each sat & sun to do the job including the remotes. and yes the loader has the update. Oh and it was either the guy in the greasey coveralls or the wife, and I might lose the tractor to her if I had done that.
Gary
2015 Kenworth T680 (A64127)
2015 Kenworth T680...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
Ford 2000 Tractor (A65579)
Ford 2000 Tractor...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2021 Caterpillar 306 CR (A64126)
2021 Caterpillar...
