Thumb Backhoe Thumb Installation
/ Backhoe Thumb Installation #1
hayden
Elite Member
VT
Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
A number on months ago I bought a thumb for my backhoe, and finally got around to installing it this past weekend.
The Thumb is from Rankin Equipment, and is the smallest model they make. It seems to fit well on my 7 1/2' Kubota 4690 BH.
This picture is is thumb before installation.
Here's another shot of the thumb welded to the dipper stick. I do not have a career as a welder - that's for sure. At the same time, my litle Hobart welder did a pretty good job.
Here it is all together with the mounting base painted to match the tractor BH color. After LOTS of grinding and with the camera at a healthy distance, my weld joint doesn't look too bad (ignore the pock marks).
/ Backhoe Thumb Installation #4
Nice looking thumb. Looks very well built. How much did you have to give for it?
/forums/images/graemlins/smile.gif
It was around $450 with shipping. It is quite beefy, yet I managed to bend it already, however it was totally my fault. I lifted a VERY large, long rock from one end, and it twisted as I lifted bending one of the tooth points. I'm luck I didn't do more damage. Stupid move on my part.
Lesson: Always lift something from it's center so it's balanced.
That said, the thumb is great. It's another one of those "I can't believe I waited so long to do this" attachments. I picked and plicked a number of rocks, stumps, and other crap. Very handy.
/ Backhoe Thumb Installation #6
Re: Backhoe Thumb Installation *DELETED*
Post deleted by Junkman
/ Backhoe Thumb Installation #7
<font color="blue">You can do my welding anytime..</font>
Looks fine to me, you should see mine. It is not pretty(mine), but it holds. I need to show some homemade stuff, one of these days.
/ Backhoe Thumb Installation #8
Just built a thumb for my bradco 509, I used 3/4" T1 steel for the claws, when I welded it up it changed the alignment on the main pin, so I tried a 20 ton jack to realign it, did'nt even phase it. I finnaly ended up heating it for over 1/2hr to a dull red and applied 12 tons of force on press to get it back-- wondering how big that rock was to bend the claw /forums/images/graemlins/confused.gif
/ Backhoe Thumb Installation #9
How about adding a picture or two? I also have a model 509 and would like to see how you attached yours. Did you attach the claws to the linkage pins or ??. Thanks
/ Backhoe Thumb Installation #10
Sorry, no digital camera, can't post pictures--
But I can explain what I did, my 509 came with thumb mounts welded to the dipper, only problem was bradco wants $820 for the fixed thumb and over $1500 for the hydrulic one, not exactly cheap but very well built. No other thumb will work with it because its set up to piviot on the main bucket pin. What I did was ordered the main pin from bradco (1 3/8" x 15" cost $35) and turned some T-bushings on my lathe to reduce the pin diameter on the leg mount thats welded on dipper, 1 3/8" to 1". bradcos fixed thumb has a folding leg, after thinking about it I decided to use a telescopic leg-that way I could get the strength of the fixed leg and the adjustabilty of the hydraulic leg, so what I used was some 2" square tube sliding in 2 1/2" tube, and drilled holes to allow different lengths on the leg, I welded 2"x 1" seamless tube(not cheap), to the ends of the square tube, this leg weighs 33#.
For the claw , my son was going to a welding trade school, I made a pattern on black poster board and took it to his school, they had this plazma cutter that followed my pattern and we cut the side plates out of 3/4" T1-- very cool to watch this. I then turned some 2 1/2"x 1 3/8" bushings to go on the bucket end of thumb, pared up the plates and drilled 1 3/8" and 1 1/2" holes for the pivot pin and main support rod (no easy task thru 1 1/2"of T1 steel) welded claws to 1 1/2" rod, welded 1/2" gusset plate from 1 1/2" rod to sides, fab 1/2" contour tabs with 1" holes for leg and storage, straighten after welding sand blast and paint------
This was no easy project , but was a good father son project, and kept him interested in school /forums/images/graemlins/smile.gif
After typing all this I see where " A PICTURE IS WORTH A THOUSAND WORDS " /forums/images/graemlins/crazy.gif
Probably need to get a digital camera, I work on consumer electronc equipment--- just hate how they ladder joe consumer thru all the latest and greatest toys only to be outdated in no time- it is planned that way /forums/images/graemlins/mad.gif
/ Backhoe Thumb Installation #11
<font color="blue">After typing all this I see where " A PICTURE IS WORTH A THOUSAND WORDS "
</font> Exactly And the cost issue is precisely why I was asking how you made yours. Amazing what some places charge for their stuff, BUT that's what makes the "world go 'round and 'round ". You only used two claws? The 2" by 1" was welded 90 degrees to the 2" by 2" ?
Inquiring and cheap people want to know! /forums/images/graemlins/laugh.gif
/ Backhoe Thumb Installation #12
Yes the 2x1 tube is welded at 90- 3" long on the 2 1/2" square tube (1/4" wall) this fits up in the mount they provided, 5" long on the 2" square tube (3/16" wall). what I did was used a tubing notcher (harbor freight) on the ends- 2" hole saw
The thumb is 12" wide x 30", it won't work with 12" bucket 15" and up, yes 2 claws like most others- but very stout, weight 89lbs with the 1 3/8" pin + 33lbs for the dead leg, pin part# 16453. the 2 1/2" tube is also drilled 1" at end and down aways from the 2x1 tube to hold it up for storage-- the leg pins in the middle hole of the existing mount and swings up to dipper along with thumb and locks in with a 1" pin - thru the holes closest to the bucket, also thru the 1/2" tabs on thumb. adjust range is great all the way from about a 90 to the dipper to enough to grab a 12" pipe with the bucket fully uncurled
My daughter is getting married at our house this weekend, I'am sure there will be a bunch of digital cameras here- I will try and get some pictures and post them /forums/images/graemlins/smile.gif
/ Backhoe Thumb Installation #13
That will be a delicate moment... daughter's big day and dad adjourns with one or more guests to take equpment pics out in the shop. Better play that one just right or you could be in the doghouse with both daughter and wife for quite a while. Suggestion: Don't wait until everyone is in uniform! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
But congratulations anyways!
/ Backhoe Thumb Installation #14
GOOD advice grandad, I will have to play it by ear getting pictures of tractor stuff that day-- maybe a little bribe to photographer to keep him quite. heck whats a couple of 11x14 photos amongst I am sure the HUNDREDS of photos wife will have him take /forums/images/graemlins/smirk.gif
Wife has ben working me like a dog getting EVERYTHING ready for this wedding--- paint the house, paint and reroof shed, cleanup entire yard (3/4 acre) pond, pool, etc etc. I think she owes me a couple of pictures /forums/images/graemlins/smile.gif
Gota go , she caught me on the computer-darn slave driver /forums/images/graemlins/frown.gif
207923 (A63290)
207923 (A63290)
2019 Toyota Camry Sedan (A66738)
2019 Toyota Camry...
(INOP) 2006 INTERNATIONAL 7400 DUMP TRUCK (A65057)
(INOP) 2006...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
2015 SABRE 5TH WHEEL (A67714)
2015 SABRE 5TH...
CASE CX60C EXCAVATOR (A65056)
CASE CX60C...
