Backhoe Side to Side -- Stuck?
   / Backhoe Side to Side -- Stuck? #1
TWD
Sierra Nevada Mountains - CA
Kubota M59
I was digging a hole with my Kubota m59 Backhoe and suddenly it went to the right (when facing rear) as far as it could go, and is holding itself there touching my stabilizer.
I cannot reposition it.
I came back the next day and it had no problem, started up centered, and it stayed there for my next 1-2hr project.
Fast forward a day later I needed to go do another project and I get 100' away driving and once again it goes far right max position, and now it won't center or let me center it.
I popped off the cover to see the controls and nothing is sticking or getting hung-up that I can see.
Position sensor? Valve? Dirty Screen? I have no clue what this could be but it seems to be either "on" or "off" no in-between bleeding off causing it to slowly move.
   / Backhoe Side to Side -- Stuck? #2
I do not know the M59, but you may have a position sensor, and semi-automatic swing control. My old Kubota B20 had that, which was pretty low-tech, but did feature a couple of solenoid valves and just some contact fingers to detect the position.
The owner's manual talked about it, so you don't have to have a service manual, tho I would still get one.
Glad Kubota dumped it on the B21. Lots of M59 owners on TBN.
Pickup Truck (A59230)
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
3 Point Hitch Receiver (A57454)
3 Point Hitch...
Trailer (A59231)
Trailer (A59231)
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
