Backhoe Side to Side -- Stuck?
/ Backhoe Side to Side -- Stuck? #61
I would think lower temperature probe would identify the outlet. I wasn’t exactly sure which side either.
Thinking temperature under 200F normal. Maybe even 240F. People are poor thermometers so your data is way better. Spot checking backhoe boom and FEL lift cylinders with non contact IR thermometer could add reference data. There is value in information. I know enough to be humbled by my ignorance.
The first gen B20 had a flat plate hydraulic oil cooler in front of the radiator. Newer B26 uses just convoluted metal tubing.
Hot smell of hydraulics is a symptom of air entrainment usually on suction side. Any external leaks can also leak air and contamination back into a hydraulic system. Unwanted air in any hydraulic system causes overheating and poor performance. People concerned about running hot should troubleshoot the easy stuff first.
All the backhoes I have run have got hot with heavy use. Smaller ones you tend to be closer to the cylinders.
I'm not even sure that hydraulic cooler has a specific output. Can you tell?? I just cannot tell from Kubota's schematic. Does the flow through the cooler depend on whether the power steering is being used??
I thought I could tell by the temperature difference too. But so far I only get a couple of degrees difference, and that could be due to anything...probably heat transfer through the mastic. I'm thinking I may instrument the backhoe separately just to see if it is different. It's cheap enough to do.
Ultimately I'd like to be able to say that fluid temperature is or is not related to whatever causes some of the Kubota TLB backhoes to have an occasional problem with their swing power. tr
Depending on who you believe, the real problem with tractor high temperature hydraulics is that trans/hydraulic fluid ages faster - loses shear-resisting lubricity additives - at high temperatures. That hi-temp aging is one reason why pure hydraulic fluid is often made with alcohols or something other than a petrochemical oil base. If you know of any good technical articles on trans/hydraulic fluids I'd be interested.
I don't know much about the state of IR gun technology. I haven't tried an IR gun since about 5 years ago when I bought several and tested them. At the time, they were not even close to what I measured with a contact type thermister. The guns were not repeatable on metal, and slightly better on non-metal surfaces - but not good enough for absolute temperature. Maybe since then the IR guns have solved their emissivity/reflection problem - or whatever their problem was.
rScotty
/ Backhoe Side to Side -- Stuck? #62
Understand getting good representative temperature measurement. All methods required some technique. Do like magnetic simple bimetal coil thermometers for things like motors, metal pipe or cylinders in the temperature range we are dealing with.
Oil break down, water emulsion, age all reasons to evaluate higher temps and determine maintenance schedules. Don’t have good comprehensive literature just bits and pieces gleaned from experience. Do believe preventative maintenance does pay rewards in the long run. Thinking the Kubota maintenance schedule are conservative for my hobby use. Buy my equipment is used so I’m operating in the long run long run lifespan.
Now you have a mechanism to read temperatures and could see how driving around compares to backhoe operations. We will have you looking more like a space shuttle than tractor soon.
I want to update that mine has had issues again and every-time I open up to check the pin is stuck.
I originally cleaned it, so I thought... but this time I ran it for hours in my ultra-sonic cleaner at a higher temp and it came out MUCH cleaner. I'm not sure if the overheat hydraulic system "baked it" with mm or so of black gunk but when that is stuck it doesn't work as expected, with it free moving it works 100% fine. I popped off all the gaskets off and ultra-sonic cleaned EVERYTHING in carb\engine safe cleaner (made for ultrasonic cleaner).
I think this may be a combination issue:
1) 100% from pin getting stuck
2) pin gets stuck from hydraulic fluid baking on the pin making it not move smoothly
3) hydraulic fluid baking on the pin is from over-heating the fluid, or, possibly just running it very hot (within spec) for long-periods of time. Not necessarily running at high rpm for long periods but running it very hot (ie: hard use)
I've yet to find any contaminants in my fluid like others have mentioned finding little pieces of something.
Since I've been able to fix mine at least 4 times now by cleaning that pin (before this deep-clean) I'm rather sure I've isolated the problem to the valve\pin and the heat.
Thanks! The only thing left I might do is add an extra hydraulic cooler... I need to read up on how the current one works.
I'm wondering if maybe the backhoe return fluid is avoiding the cooler and dumping back into the tank which is why when using the backhoe for 3+ hours it gets VERY HOT even if the cooler is clean. It would be easy enough to add one between the return QC and the backhoe, and mount it somewhere flat underside, with a skid\protection.... just not sure that's worth it, nor what pressure the return line is yet.
My 15g capacity log splitter fluid overheats too after ~6hrs of continued use and starts spewing fluid from expansion, I plan to add a cooler to that too.
Needing to add coolers to all my hydraulic systems... makes me think we may be hitting the wall of consumer\construction equipment by running it for so many hours at once, and in non-cool weather. I doubt commercial or industrial equipment has this problem considering they're often used multiple shifts per-day.
/ Backhoe Side to Side -- Stuck? #66
Interesting. rScotty was getting some temperature differential data on the hydraulic cooler. Better? Bigger? or electric fan cooled? Maybe monitor backhoe supply and return? Upper valve block temperature?
The hot fluid from the cylinders which goes thru the valves is too hot? The tractor hydraulic cooling may not be the only problem.
Weld some cooling fins on the cylinders? Sometimes see some interesting aluminum extrusions at the scrapyard that could be hose clamped to the cylinders.
Maybe adjust technique by exercising the cylinders periodically with no load, full extension/retraction to circulate fluid to remove heat.
Maybe a small electric fan to ventilate the backhoe valve block control pedestal?
I’m sure excavators take credit for their large cylinders for heat removal.
I find age helps limit my tractors overheating issues. Picking cooler weather and shorter shifts.
Wonder too if the black coating could come from inside aging hydraulic hose?
Had a M5030 that would lose power steering. Had a fine stainless steel filter in the pump reservoir. Looked clean. Rinse with brake cleaner would remove considerable black coating restoring power steering.
/ Backhoe Side to Side -- Stuck? #67
TWD
Did you buy the machine new or used?
How many hours are on your machine and how many hours since ALL 3 hydraulic filters and hydraulic fluid replaced?
Has anybody added or "fixed" a leaking hose or connection anywhere in the hydraulic system and possibly contaminated system with dirt, metal particles, or teflon tape? The dark material may indicate you have fluid breakdown due to age, contamination with moisture, incompatible mixture of different hydraulic fluids.
I've also experienced the hoe improper operation after purchasing a 230 hour/ 5 year old machine used M59. First was failure to swing left or right if immediately asked to do so upon machine startup but after machine ran 5 minutes then swing operated properly. Second would be running backhoe for several hours and upon getting machine ready for storage in shed the swing operation would fail on left or right motion. Third was inability to grasp anything, with any degree of force, between hydraulic thumb and bucket because thumb would easily push bucket around. Originally ruled out low fluid and then discovered dirt stuck in relief valve on bucket curl cylinder causing valve to relieve any pressure that thumb placed on curl cylinder. Finally took machine, with 1100 total hours, to local Kubota dealer with mechanic who was old, crotchety, had gray hair, greasy hands, and lots of knowledge spanning many different tractor, skidsteer, excavator , etc manufacturers. He determined that all three hydraulic filters were factory original installation and were seriously plugged, therefore cold hydraulic fluid ( issue #1) flowed slowly thru filters until warmed by pump then swing would function. He dumped dirty fluid, flushed system, and refilled with clean hydraulic fluid.
I'v had no issues with backhoe hydraulic controls, now with more than 1000 additional work hours, since fluid and filters changed even after digging all day to the point where I can not hold my hand on the cylinder attached to boom and dipper stick due to very high temp. I've not measured boom cylinder but its at least 120-130'F. I'm thinking you have dirt in the hoe hydraulic fluid that may not be making it back to the reservoir and this is causing you sporadic problems. The valve stack on the backhoe is serviced by 2 pumps that add flow from opposite ends of the valve pack with one of pumps being dedicated to providing flow specifically to the swing control valve located at far left ( when sitting in hoe operator seat). Since these valves are all power beyond then any excess flow/ pressure is available to valves that are being operated. This allows multiple operations of swing, boom and dipper movement, and bucket curl to occur at same time but also may allow dirt to circulate within valve pack or between valve pack hydraulic cylinders without making it back to reservoir.
TWD
I'm original\new owner.
The fluid was fresh as were all 3 filters.
The only new hydraulic anything was 5+ years ago, and the fluids have been changed at-least 2x since then. Yes, my cylinders get that hot when operating as well. The fluid was not dirty, different color, off-color, hazy, or in any other way contaminated, my assumption was heat, as my radiators were partially clogged due to the conditions I operate in, and that's why I assumed some fluid baked onto the small pin not allowing movement. Either way, once I cleaned it, it worked as expected. I've taken apart the valve stack components to examine, and clean, and all of them are spotless that I've looked at.
I purchased a new valve for the swing (one direction) and installed that, and the pin IS coated with something, my old one was NOT anymore, it was worn out, which is why I think a very-very thin layer of hydraulic fluid film or "burn on" hydraulic fluid was causing it to not function as expected. Note- I did not replace the left and right valves, just one that was causing the issue. (important to note for anyone reading this in the future that each direction needs it's own, you'll see this as one on top the valve stack and one on the bottom for each function)
Either way, wanted to update this thread with the "I replaced it with a new one" ($700) for piece of mind, and kept the old one as a spare, spare components, etc...
I actually just made a new post about the backhoe leaking down in under 5 hrs with 0 leaks, and rebuilt cylinders, I'm thinking that valve is not closing entirely or check valve is allowing bleed-back, hoping someone smarter than me can tell me what to look at first and save me some time troubleshooting ;)
Also, fwiw, after replacing cylinders the backhoe fully doesn't operate because they're empty, and you'd expect running other functions through the valve would move fluid where it needs to be... but no, that wasn't the case. After 20 minutes of wondering how I was going to get the backhoe re-connected without the boom cylinder moving I decided to move the FEL and sure enough, that's all I Needed to do, and the boom cylinder came to life!! So, anyone reading this -- hope this saves you some time ;)
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
