rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,908
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I would think lower temperature probe would identify the outlet. I wasn’t exactly sure which side either.
Thinking temperature under 200F normal. Maybe even 240F. People are poor thermometers so your data is way better. Spot checking backhoe boom and FEL lift cylinders with non contact IR thermometer could add reference data. There is value in information. I know enough to be humbled by my ignorance.
The first gen B20 had a flat plate hydraulic oil cooler in front of the radiator. Newer B26 uses just convoluted metal tubing.
Hot smell of hydraulics is a symptom of air entrainment usually on suction side. Any external leaks can also leak air and contamination back into a hydraulic system. Unwanted air in any hydraulic system causes overheating and poor performance. People concerned about running hot should troubleshoot the easy stuff first.
All the backhoes I have run have got hot with heavy use. Smaller ones you tend to be closer to the cylinders.
I'm not even sure that hydraulic cooler has a specific output. Can you tell?? I just cannot tell from Kubota's schematic. Does the flow through the cooler depend on whether the power steering is being used??
I thought I could tell by the temperature difference too. But so far I only get a couple of degrees difference, and that could be due to anything...probably heat transfer through the mastic. I'm thinking I may instrument the backhoe separately just to see if it is different. It's cheap enough to do.
Ultimately I'd like to be able to say that fluid temperature is or is not related to whatever causes some of the Kubota TLB backhoes to have an occasional problem with their swing power. tr
Depending on who you believe, the real problem with tractor high temperature hydraulics is that trans/hydraulic fluid ages faster - loses shear-resisting lubricity additives - at high temperatures. That hi-temp aging is one reason why pure hydraulic fluid is often made with alcohols or something other than a petrochemical oil base. If you know of any good technical articles on trans/hydraulic fluids I'd be interested.
I don't know much about the state of IR gun technology. I haven't tried an IR gun since about 5 years ago when I bought several and tested them. At the time, they were not even close to what I measured with a contact type thermister. The guns were not repeatable on metal, and slightly better on non-metal surfaces - but not good enough for absolute temperature. Maybe since then the IR guns have solved their emissivity/reflection problem - or whatever their problem was.
rScotty
