Backhoe hydraulic hook up
/ Backhoe hydraulic hook up
Thank you for all your input it was very helpful. JJ was right the hose on the right hand side (T1) was mislabeled, sorry my mistake, It is in fact the PB line going back to my rear remotes. So all I have to do is tap into that line correct?
Thank you for all your replies. Now I feel like I know a bit more about hydraulics.:D
PS.. I will post pics of the final result as well as my tractor and backhoe.
/ Backhoe hydraulic hook up #22
Maybe, it depends on what you mean by tap. Any new valve has to be in series with the flow, not just tap into. Do not use a tee to tap into the pressure line.
/ Backhoe hydraulic hook up #23
I accept: The more hose , joints, fittings, orifices, the fluid is flowing through, the more heat is generated. It should be kept simple. Changing out the rear remotes would be the more simple way, using detented valves, and using the BH off the rear remotes.
(2) Firestone 420/90R30 Clamp on Duals (A60463)
(2) Firestone...
Giyi LW45 QA Hydraulic Winch (A60463)
Giyi LW45 QA...
PENDING SELLER CONFIRMATIONS (A59908)
PENDING SELLER...
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
