Backhoe hydraulic hook up
/ Backhoe hydraulic hook up
Thank you for all your input it was very helpful. JJ was right the hose on the right hand side (T1) was mislabeled, sorry my mistake, It is in fact the PB line going back to my rear remotes. So all I have to do is tap into that line correct?
Thank you for all your replies. Now I feel like I know a bit more about hydraulics.:D
PS.. I will post pics of the final result as well as my tractor and backhoe.
/ Backhoe hydraulic hook up #22
Maybe, it depends on what you mean by tap. Any new valve has to be in series with the flow, not just tap into. Do not use a tee to tap into the pressure line.
/ Backhoe hydraulic hook up #23
I accept: The more hose , joints, fittings, orifices, the fluid is flowing through, the more heat is generated. It should be kept simple. Changing out the rear remotes would be the more simple way, using detented valves, and using the BH off the rear remotes.
2021 TAKEUCHI TB240 EXCAVATOR (A65056)
2021 TAKEUCHI...
2020 Nissan Murano SUV (A66738)
2020 Nissan Murano...
2023 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2023 WEILER K560...
2012 DRAGON 165BBL ALUMINU VAC TRAILER (A67714)
2012 DRAGON 165BBL...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
3144 (A63117)
3144 (A63117)
