Backhoe fell over and died.
   / Backhoe fell over and died. #21
It sounds like either you are getting nothing out of the power beyond circuit, OR, if you are, something on the hoe is letting it all bypass right back to the tractor.
As someone else mentioned, can you pull the loop of hose and hear anything change in the tractor's sound? That would indicate that it's dead headed with pressure and would indicate that there's flow available.
   / Backhoe fell over and died. #22
Another way, I guess, would be to measure the temperature of the loop of hose when the machine is cold, run it for 10 minutes, and measure the temp of the hose again. If it's significantly warmer, you know there's fluid going through it.
   / Backhoe fell over and died. #23
When you don't have the hoe on does the loader work correctly?
Is your setup one of the ones that you have to connect a bypass loop when you do not have the hoe on?
When you attempted to connect to the hoses was your loader still functional?
I am assuming that the two hoses you hooked up to from the hoe did not go to the same fittings as your bypass line does.
Do you have a pressure feed at the rear of your tractor?
There was a discussion recently were the tractor had 3 fittings at the rear,
a power (pressure feed),
a return to tank,
and a power beyond.
That hoe hooked up to the power (pressure feed) and the return to tank,
with the hoe removed the bypass line went from pressure to power beyond to power the 3 point.
Yup, that was mine, glad we finally got that figured out!
   / Backhoe fell over and died. #24
It looks like the boom is fully swung to the side. Probably settled that way when it fell over. I don’t know enough about hydraulics to know if that is creating a problem. I know if I take my loader off in the sun it gets pressure in the lines and makes it hard to hook up. Are the lines for the back hoe hooking up ok? Are they feeling like they hooked up but aren’t connected well?
   / Backhoe fell over and died. #25
My swing cylinder is not very strong and will not push much dirt sideways when trying to fill a ditch or hole. OP's may not be strong enough to swing the boom from that position, but he should be getting some indication of it trying. Outriggers and curl should also be trying to do something.
Good idea, will try that, thanks
   / Backhoe fell over and died. #27
At last resort can make a tripod over back-hoe to get it up right.
   / Backhoe fell over and died. #28
I would say that if 3pt is working and remote valves are working, you are getting flow through the power beyond. I also suggest getting someone to help you with standing the hoe back up. An extra set of hands and eyes will go a long way. Just be careful.
   / Backhoe fell over and died. #29
Hook on to the bucket and pull the boom straight. Then get some blocks and a hydraulic jack and start the slow process of getting it upright.
The tripod and chain fall will be the easiest and fastest way.
Forget the temporary hydraulic hookup and just work on getting the hoe upright.
   / Backhoe fell over and died. #30
Do you have rear counterweight? It seems that a 4520 would lift it with appropriate counterweight.
Tractordata specs on the 4520 loader lists 3800 lbs lift to full height.
It should easily be able to carefully stand the hoe up with a little judicious rigging and a few spotters.
Getting it upright may make other problems go away.
   / Backhoe fell over and died. #31
Positioning may be difficult:
My location makes it difficult, a level spot on 'terraced' hillside.
That may impede a tripod too. Then there's the weight. I've used a tripod of 4x4s and one ton chain fall. It wasn't easy to get everything aligned to be able to lift. For the weight of that hoe, he may need to go bigger which will make it even more difficult for someone not in top health.
Why, is there some kind of 'tilt switch' like check valve in the hoe's SCV perhaps?
   / Backhoe fell over and died. #33
Attach a tractor tie down chain (min 12' length) to the loader bucket, keep it short to moderate in length, and wrap it around the backhoe, and lift the backhoe into position for the mounting on the blocks. Your loader can handle the weight. Put some implement on the rear as counter ballast. This could take an entire day to get it repositioned, then once in proper position, I suspect your BH hydraulics will be just fine and operational.
   / Backhoe fell over and died. #34
Tripod support works well on uneven terrain. Proper sized tree trunks work well for tripods.
A gin pole arrangement with chain fall would also work. It would be quite easy to set up with a tractor with no major heavy lifting involved.Then a third leg could be added with the chain fall or just use the gin pole.
That was pretty much my first attempt, placing cinder blocks and timbers underneath while going along until the tractor started tipping; at this point I decided that hydraulics were going to be more controllable than gravity (working alone). It's looking like I'm going to have to bite the bullet and replace the 3 point linkages (heavy and not fun anymore), mount the brushhog with a lot of cinder blocks on deck, and take my time, using some well positioned ropes and metal t-posts, to keep it from tipping over to it's other side.
   / Backhoe fell over and died. #36
also if you are going to try to reposition the hoe, you may need to remove the couplers on the ends of the hoses and you may need to tie the control valve in the position
you are trying to work the cylinders, ie the swing motion lever , push it in the direction you want it to go and tie it off there so oil is not holding the cylinder /boom rigid..
Ran at PTO speed for about 5 minutes and the hoses got good and warm. I'll post some pix of the hookup.
   / Backhoe fell over and died. #38
does the three point hitch go up and down normally with the hoses connected?
Pix of the hookup
Pix of the hookup
The fully extended swing piston shows the only evidence of rust/corrosion as asked about above.20201010_104049.jpg20201010_104029.jpg20201010_104244.jpg
UNUSED RAYTREE RMA42 HYD AUGER (A60432)
UNUSED RAYTREE...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
