Backhoe Backhoe bucket size
/ Backhoe bucket size #1
Michael_S
North East Texas
Kubota L3830
I have the chance to purchase a slightly used Bush Hog 765 backhoe for use on my Kubota L3010. It does not include a bucket.
What size would you guys recommend?
Should I buy more than one size?
Thanks
/ Backhoe bucket size #2
Have been shopping myself for a BH. They tell me buyers typically get one mid-sized, all-purpose bucket, say 14-18 inches for a 9 ft. hoe and maybe a bit smaller for the 6.5 or 7.5 ft. hoes. Obviously, the more powerful the hoe, the better it can handle a larger bucket. A large bucket, say 24" or more, can get expensive.
Also, your local digging conditions are a factor. Texas has some tough, rocky soil in many places, where a smaller bucket would have some advantages.
/ Backhoe bucket size #3
Hi,
If you are getting only one bucket I would get a 16 inch or so.
I have 10 and 16 inch buckets, and the ten is too narrow for normal use in many cases. I do find it good for pipe trenches and also stump digging, where it concentrates the forces a little more.
The 10 inch does not clear itself easily in sticky clay, but the way. In sticky soils a wider bucket is better.
One bucket...16 or 18 is probably the way I would go... /forums/images/graemlins/smile.gif
/ Backhoe bucket size #4
Hi...
Agree... 12" - 18"... check prices before you decide on 1 or more... also... how the teeth are attached/replaced & cost...
Dave...
/ Backhoe bucket size #5
I have a small back hoe a bx22 modle 600 it has a 10" bucket I have hard dry rockie soil . [ unless it rains for a while ] I wish I could ger a smaller bucket maby 8" - 6" for digging out tree roots and for my hard soil. I may have to get a larger bucket and have a welder cut out a section and and weld it back together. Last time I checked Kubota only supplied a 10" and a 12" bucket any suggestions for sources for a smaller bucket. Thanks David.
/ Backhoe bucket size #6
I went with two buckets for my Woods 9000, 12 and 24". The 12" was for trenching water, sewer, communications etc.. Its' a little tight but workable.
The 24" is for digging anything else like septic tanks, drain field, culvert, etc...
If I could only pick one bucket it would be the 18 or 24".
/ Backhoe bucket size #7
I agree it should be a 16" - 18" size bucket. Three main reasons: <ul type="square"> [*](1) It will clear itself more easily than a smaller 12" bucket. [*](2) It's not so big meaning most backhoes can power it [*](3) If you are trenching, it's wide enough that you can get down in the trench and move pipes around, etc. [/list]
Location Info Please
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2022 EZ-GO ELITE...
