Buying Advice Backhoe and remotes
/ Backhoe and remotes #1
GMC Cooker
Ridgely Md
2017 LS XJ 2025H TLB
I'm about to pull the trigger on a xj2025 and my question is if I order it with a backhoe will that automatically give it a remote on the rear of the tractor for the Backhoe to hookup too
/ Backhoe and remotes #2
No. They put in a power beyond valve in the loader valve and run the line to the BH. You have to order the remote kit separate if you want it but keep in mind that remote hydraulic valve will need to be engaged (detent kit sold separately) when you want to use the BH. With the power beyond its always getting pressure.
/ Backhoe and remotes #3
and additional info... when the BH is removed from the tractor, the line need to be plugged into the priority valve block under the seat to restore the hydraulic circuit
/ Backhoe and remotes #4
Mine has the remote. It is a good way to go especially if you are considering remotes in the future.
/ Backhoe and remotes #6
/ Backhoe and remotes #7
With mine, the original hose didn't reach. The dealer gave me an extension with couplings.
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
Case CX75C (A62177)
Case CX75C (A62177)
2023 Bobcat L28 (A64126)
2023 Bobcat L28...
2005 DRAGON END DUMP TRAILER (A65643)
2005 DRAGON END...
2017 Subaru Forrester (A62613)
2017 Subaru...
