Buying Advice Backhoe and remotes
/ Backhoe and remotes #1
GMC Cooker
Ridgely Md
2017 LS XJ 2025H TLB
I'm about to pull the trigger on a xj2025 and my question is if I order it with a backhoe will that automatically give it a remote on the rear of the tractor for the Backhoe to hookup too
/ Backhoe and remotes #2
No. They put in a power beyond valve in the loader valve and run the line to the BH. You have to order the remote kit separate if you want it but keep in mind that remote hydraulic valve will need to be engaged (detent kit sold separately) when you want to use the BH. With the power beyond its always getting pressure.
/ Backhoe and remotes #3
and additional info... when the BH is removed from the tractor, the line need to be plugged into the priority valve block under the seat to restore the hydraulic circuit
/ Backhoe and remotes #4
Mine has the remote. It is a good way to go especially if you are considering remotes in the future.
/ Backhoe and remotes #6
/ Backhoe and remotes #7
With mine, the original hose didn't reach. The dealer gave me an extension with couplings.
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
Anderson 24' Tilt Trailer (A64126)
Anderson 24' Tilt...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2026 Electric Tricycle (A64194)
2026 Electric...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
