Buying Advice Backhoe and remotes
/ Backhoe and remotes #1
GMC Cooker
Ridgely Md
2017 LS XJ 2025H TLB
I'm about to pull the trigger on a xj2025 and my question is if I order it with a backhoe will that automatically give it a remote on the rear of the tractor for the Backhoe to hookup too
/ Backhoe and remotes #2
No. They put in a power beyond valve in the loader valve and run the line to the BH. You have to order the remote kit separate if you want it but keep in mind that remote hydraulic valve will need to be engaged (detent kit sold separately) when you want to use the BH. With the power beyond its always getting pressure.
/ Backhoe and remotes #3
and additional info... when the BH is removed from the tractor, the line need to be plugged into the priority valve block under the seat to restore the hydraulic circuit
/ Backhoe and remotes #4
Mine has the remote. It is a good way to go especially if you are considering remotes in the future.
/ Backhoe and remotes #6
/ Backhoe and remotes #7
With mine, the original hose didn't reach. The dealer gave me an extension with couplings.
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Bobcat T650 (A64126)
2017 International 4300 Box Truck (A62613)
2017 International...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2026 Electric Tricycle (A64194)
2026 Electric...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
