Backhoe advice - thanks
/ Backhoe advice - thanks #1
BubbaBillyBob
Rockbridge, MO
Mahindra 5545 4wd
All--
Quite some time ago, I was reading everything I could about backhoe operation. I have a Mahindra 5545, 4WD and a frame mounted backhoe, plus some other stuff.
An experienced backhoe operator wrote that it was not necessary to run the engine at brush hog speed; 2100rpm for me. I knew that was wrong, of course.
But I tried it anyway. Ha! The guy that was wrong was me! Now, I set the throttle to whatever rpm I think the job requires, which is almost always well below 2100rpm.
I do not know who that guy is, but it is long past time that I thank him. THANK YOU.
--Bill
/ Backhoe advice - thanks #2
Yep! Folks on here are very knowledgeable on a lot of things, not just tractor stuff. I find it amazing the wealth of knowledge here and the willingness to share it.
Also, when you run hydraulics, not just backhoe, the engine speed determines how much flow you have. If you're trying to be accurate and move the implement slowly, you'll want a low engine speed. You'll have a slower movement rate than if the engine is at full rpm. Also, keep in mind that turbo charged engines have a "fast idle" speed to avoid "wet stack". Mine is 1200 rpm. I run my engine a little above that for hydraulic implements.
/ Backhoe advice - thanks #3
agree with slower rpms unless............................................... DPF wants higher exhaust temps than say 1500 rpm generates. So depends on what your machine is designed for.
For sure slow flow rates can be big beneifit especially for inexperianced operators or machines whose quality of valves maybe not the highest. Can help operator be smoother. On larger / newer / commercial machines though we don't throttle back excavators or backhoes.
somewhat matter of preference but also depends on what machine.
Cheers and Merry Christmas all
/ Backhoe advice - thanks #4
Sure helps to slow down as you are learning the machine, or working close to something you don't want backhoed. :whistle:
/ Backhoe advice - thanks #5
I agree with this, after running backhoes for the last 25 years. Lots of variables.
/ Backhoe advice - thanks #6
True, If working near a building running my 550 Ford TLB at higher revs, it would be like asking to bang the boom into a building with the "touchy" swing control it has
/ Backhoe advice - thanks #7
I've never ran a backhoe that required high engine speed. Half throttle is usually more than enough.
2011 Chevrolet Express 2500 Cargo Van (A64556)
2011 Chevrolet...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2016 Chevrolet Express 2500 Cargo Van (A64556)
2016 Chevrolet...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A65563)
1999 Van Hool...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
