Back up Cameras?
/ Back up Cameras? #11
So for anyone interested. The Haloview can receive up to 4 cameras. 7" monitor, 720P resolution. The monitor can be set for split screen for 2,3 or 4 cameras or single screen for 1 camera so that the camera resolution is really good and viewable. It has the mirror function so that you can see as if you are turned around looking or looking in a mirror. Power must be provided for the monitor and cameras. The monitor comes with a hard wire pigtail or a cig lighter attachment. It has a perm mount bracket or a temp mount bracket. It also has wiring so that you can install a selector switch to switch between monitors so that you don't have to finger the buttons on the monitor. It selects any camera and whichever split screen you have selected. The cameras are IP69 water proof which is the highest waterproofing there is. Be careful here. Most cameras aren't IP69, they are IP67 or 68. The cameras have perm mount or you can buy optional mag mount. You can also buy a battery pack in case hard wiring power is difficult. I bought this for my loader mounted camera. This system comes with one camera. I bought 2 extra plus 3 mag mounts and a battery pack. $569 if I remember correctly. For everything. I'm installing 2 cameras for rear view and one on the loader. This is an awesome system. No idea of it's longevity yet. The monitor is NOT waterproof.
/ Back up Cameras? #12
fwiw
I just received this from Amazon yesterday:
I don't operate my tractor in the rain so having a waterproof monitor isn't important. For snow removal I'll probably just put a plastic bag over it. This one comes with 2 cameras and can operate split screen or you can select one camera. It's 9" diagonal and 1080p. I hooked it up in my basement to check it out and I think its going to be perfect for me. Both cameras will be rear mounted. One will face down at the rear implement and the other straight back. For my current project of regrading my driveway with the box blade it's going to be a neck saver.
I finally decided to mount it on the FEL plastic valve cover with 3 magnet strips:
Today I added a switched 6 position fuse block on the inside of the right fender. It will power the camera system and my ROPS mounted LED lights. Tomorrow the magnets should come in and with any luck I'll finish this project.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
STORAGE FEES (A59908)
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
Volvo EC220EL (A60462)
2025 JMR Tree Boom Skid Steer Attachment (A59228)
2025 JMR Tree Boom...
