B8200 HST 4wd
/ B8200 HST 4wd #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I'm looking at an older model of the B8200 HST 4WD for a friend. It looks good, cranks nicely, but doesn't run.No obvious leaks and from appearances was good machine before it sat for a decade or so. I don't think it has power steering unless it's internal. Tires are OK but are lug type and would probably be better with turfs for the intended use. I'm just wondering if someone has some insight into this model.
Thanks,
rScotty
/ B8200 HST 4wd #2
I have a B9200, its big brother. A surprise is that these need use of the glo plugs even in the summer. On mine that means turn the key left for about 10sec before cranking. Still, you may not be getting fuel, so check out all the usual suspects. A light spray of chainsaw premix while cranking might light it up.
207270 (A52708)
207270 (A52708)
2022 EZ-GO ELITE...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
2018 FREIGHTLINER CASCADIA (INOPERABLE) (A63569)
2018 FREIGHTLINER...
MULTIQUIP LIGHT TOWER (A63569)
MULTIQUIP LIGHT...
