B7800 won't start
/ B7800 won't start #1
bota7800
Washington State
Kubota B7800
Hello, I need some help.
My B7800 ran fine the other day but would not start yesterday. It cranks but does not fire up. It kind of acts like the hard-to-start behavior right after I change the fuel filter (which I did a couple months ago).
Short of taking off a hose, is there a way to test the fuel pump? Any other things I should check?
Thanks
/ B7800 won't start #2
First thing to check is the fuel cut off solenoid..make sure when you turn the key to the on position the solenoid plunger activates..if not check fuses.
/ B7800 won't start
Tim, thanks.
Solenoid fuse is good.
How do I check the solenoid itself?
/ B7800 won't start #5
Tim, thanks.
First find it, then make sure it works..it's an actuator. When 12 volts are applied the plunger moves. If no operation, make sure it gets 12 volts with ignition key in on position. If yes, replace solenoid.
If the solenoid is working then your problem is something else.:(
Then we find out if there is fuel delivery... I'm assuming you checked all fuses..not just looked at them. Test them for continunity.
The next item in line is the fuel pump....if the B7800 has a pump (some are gravity fed)
/ B7800 won't start
Actually, I just visually inspected the fuse. I will check continuity tomorrow. I was suspecting the fuel pump but, as you point out, it may not have one. When I disconnect the fuel line at the engine fuel flows readily like it has head.
I need to identify the solenoid. Unfortunately, I cannot find my manual - it is not where it should be.
Thanks for the advice.
2008 R&R FLATBED WINCH TRAILER (A63569)
2008 R&R FLATBED...
EZ Trail 3400 (A63688)
1063 (A63291)
1063 (A63291)
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
2008 Trail- Eze Tilt Triaxle, 42' Deck/10' Neck (A62679)
2008 Trail- Eze...
