Snow B7800 in the snow
   / B7800 in the snow #11
I'll bet you don't need chains at all. The chains will rip your driveway up if anything does.
   / B7800 in the snow
I have the "industrial" type tires. They should be o.k right? I've heard that the ag ones are good too but that the industrial was as well.:rolleyes:
   / B7800 in the snow #13
My neighbor has a new-looking B7800. Very nice tractor. He was complaining to me about clearing snow once. I asked him if he had tried using the differential lock. He said, "The what?"
   / B7800 in the snow #14
I've done only one 6" snow, but I was blown away by the immense amount of traction my tractor had with turf tires and no chains. I cleared nearly 2,000 feet of driveway in under 2 hours (7 seperate driveways) with nothing but my FEL and a cup of coffee. The steepest driveway (unpaved) is probably 15% to 20% grade. The steepest paved driveway is ~10% grade.
I'd hold on chains until you give 'er a shot. I suspect you'll be very pleasently surprised. Especially with the R4s. Personally, I'll get another set of rims with AGs mounted before I consider chains. But as mentioned, I'm pushing the limits of my turf tires every other time I use my machine.
   / B7800 in the snow
Thanks, that was all very helpful. What or How much weight do you think is a sufficient amount for ballast. I'll have a backbalde on most of the time, but would a weight box work as well? The tires are filled too.
   / B7800 in the snow #16
A weight box would works as well as a back blade. I used the back blade for a few years. Until I backed the back blade into both garage doors. :( Weight box does not stick out back as far as a back blade. :cool:
   / B7800 in the snow
That would be nice too. Who makes a good aftermarket weight box? Or fab one up? Thanks
   / B7800 in the snow #18
Kubota makes one. Some have made them out of a drum filled with concrete. Make sure it is less than 600 lbs for you B7800.
   / B7800 in the snow #19
Is there a reason you think it should be under 600 pounds. Mine is over 800 pounds for my B7800. It is perfect so far. You can actually make a 55 gallon drum 1000 pounds. That is less than 1/2 the capability of the 3 point hitch
   / B7800 in the snow
Nice machine! How do you like it? Got any pics of the post hole digger? Prices?:cool: Nice weight box too!;)
PALLET OF (6) BOXES OF SAFETY CHAINS (A57192)
PALLET OF (6)...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
(INOP) 2000 FREIGHTLINER FL60 S/A FLATBED TRUCK (A57192)
(INOP) 2000...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
UNUSED FUTURE FT36C STAND-ON SKID STEER (A57192)
UNUSED FUTURE...
2008 Ford F-250 Crew Cab Pickup Truck (A55852)
2008 Ford F-250...
