Snow B7800 in the snow
   / B7800 in the snow #11
I'll bet you don't need chains at all. The chains will rip your driveway up if anything does.
   / B7800 in the snow
I have the "industrial" type tires. They should be o.k right? I've heard that the ag ones are good too but that the industrial was as well.:rolleyes:
   / B7800 in the snow #13
My neighbor has a new-looking B7800. Very nice tractor. He was complaining to me about clearing snow once. I asked him if he had tried using the differential lock. He said, "The what?"
   / B7800 in the snow #14
I've done only one 6" snow, but I was blown away by the immense amount of traction my tractor had with turf tires and no chains. I cleared nearly 2,000 feet of driveway in under 2 hours (7 seperate driveways) with nothing but my FEL and a cup of coffee. The steepest driveway (unpaved) is probably 15% to 20% grade. The steepest paved driveway is ~10% grade.
I'd hold on chains until you give 'er a shot. I suspect you'll be very pleasently surprised. Especially with the R4s. Personally, I'll get another set of rims with AGs mounted before I consider chains. But as mentioned, I'm pushing the limits of my turf tires every other time I use my machine.
   / B7800 in the snow
Thanks, that was all very helpful. What or How much weight do you think is a sufficient amount for ballast. I'll have a backbalde on most of the time, but would a weight box work as well? The tires are filled too.
   / B7800 in the snow #16
A weight box would works as well as a back blade. I used the back blade for a few years. Until I backed the back blade into both garage doors. :( Weight box does not stick out back as far as a back blade. :cool:
   / B7800 in the snow
That would be nice too. Who makes a good aftermarket weight box? Or fab one up? Thanks
   / B7800 in the snow #18
Kubota makes one. Some have made them out of a drum filled with concrete. Make sure it is less than 600 lbs for you B7800.
   / B7800 in the snow #19
Is there a reason you think it should be under 600 pounds. Mine is over 800 pounds for my B7800. It is perfect so far. You can actually make a 55 gallon drum 1000 pounds. That is less than 1/2 the capability of the 3 point hitch
   / B7800 in the snow
Nice machine! How do you like it? Got any pics of the post hole digger? Prices?:cool: Nice weight box too!;)
2023 CATERPILLAR 259D3 SKID STEER (A52707)
2023 CATERPILLAR...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2013 Ford Escape 4WD SUV (A55853)
2013 Ford Escape...
2007 Chevrolet T7500 24 ft Box Truck (A55852)
2007 Chevrolet...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
2013 Audi Q7 AWD SUV (A55853)
2013 Audi Q7 AWD...
