B7800 fluids
/ B7800 fluids #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Hi,
Going to do a total fluid change.
Can someone just reply and tell me what kind of fluids I should use?
130 hrs on the tractor, uncertain if the 50 or 100 hr service was done. Hope so, but the fuel filter has some stuff in it so I'm not so sure.
engine oil type and filter
trans fluid type and filters
front axle type
anything else?
Dont have manuals yet. thanks again, bret w
/ B7800 fluids #2
Your hydro system uses 2 filters:
Kubota parts numbers 66021-36060 and 67955-37710
The engine oil filter is Kubota part number 16271-32092
You can use Kubota UDT fluid in the hydro, but I would use Super UDT, which is what the tractor comes filled with. You can also use Super UDT in the front axle (or 80W-90 gear lube)
As for engine oil, 10W-30 or 10W-40 with an API Service rating of CF.
The fuel filter is Kubota number 6A320-59930
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
2019 Kubota SVL95-2S (A64126)
2019 Kubota...
1997 Ford F800 Dump Truck (A62613)
1997 Ford F800...
Transfer Pump (Electric) (A64127)
Transfer Pump...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
